| Chip Amps Amplifiers based on integrated circuits |
hey guys, will be an LM4780 (bridged) good for an Subwoofer?
will be this comparable with Class D Amps? i read the Class D Amps are the best for Subwoofers, but a lot of hard to design it too ![]() please someone help me |
#2 |
What power do you need ? With one 4780 you can get 120 W / 8 Ohm, with two pieces more than 200 W / 4 Ohm.
#3 |
well i need at least 300-400 Watts
its the description of the woofer that i maybe ill use Tempest combines a low Fs (18.6 Hz), medium Vas (317L), and medium Q (0.38) with an incredibly long throw (16.9mm one way) for a subwoofer driver capable of huge deep bass output. And with a 750W power rating, you can use all that displacement, too. We've run a LOT more power through this unit than what we've rated it for. Tempest should be able to take a beating! will be great to use 4 IC in bridged mode |
#4 |
In normal connection is " border line " practically somewhere between 250 - 300 W / 4 Ohm, 'cos rails must be +/- 40 V max. . Bigger power you get only with lower load impedance.
#5 |
wich relation existe between the amount of bridget ICs and power supply?
i mean, can i bridge 10 ICs for example?
#6 |
No, you cannot. You can only bridge 2 chips (or 1 4780 - bridge the 2 amps in it). The reason is because bridging means that the positive of two amps drive half of a speaker.
What you can do is parallel 2 sets of 5 amps then bridge them. That would give you amazingly low impedence drive. |
#7 |
sounds nice
![]() some math !formula" to determine how much V and Amps i need in the power supply? |
#8 |
Electrons are yellow and more is better!
Why don't you use this Excel file?
http://www.national.com/appinfo/audi...gn_Guide13.xls http://www.national.com/appinfo/audi...sign_Guide.pdf
/Per-Anders (my first name) or P-A as my friends call me |
#9 |
Seriously, it's easier to design an amp for max 10 KHz or a bit less than that and use MOSFET's. Driving MOSFET's up to 100-200 Hz requires almost nothing in power, nor in complexity.
#10 |
thanks dude
| Looking for a Subw for AV & Audio... | lsfarzo | Subwoofers | 1 | 7th March 2008 10:22 PM |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| subw amp install ? | dbaudio | Car Audio | 1 | 27th May 2006 08:02 PM |
| LM4780 amp | Piper | Chip Amps | 0 | 5th March 2005 09:18 PM |
| Lm4780 | Cheng | Chip Amps | 10 | 4th March 2005 05:10 AM |
| Page generated in 0.09101 seconds (76.58% PHP - 23.42% MySQL) with 10 queries |
