Old 15th September 2004, 04:01 AM   #1
goering is offline goering  United States
goering's Avatar
Default Can LM317 be used as GC PS regulator?
Could you guys help me out? Can the LM317T variable voltage regulator (up to +35v output at 1.5A) be used to regulate a power supply for a bridged LM3876 or LM3886 GC?
My neighborhood electronics store ran out of LM338 and I have a bunch of 317s. I think I heard somewhere that several chips can be configured to handle more current than a single chip can. How could this be done? Or could it be done at all?
I'd really appreciate the help. Thanks and regards.
Old 15th September 2004, 05:15 AM   #2
tool49 is offline tool49  Canada
tool49's Avatar
You might want to try using transistors instead of multiple chips. Read the first, second and third parts of the following page:
http://ourworld.compuserve.com/homep...den/page12.htm
Hope this helps!
Sébastien
Old 15th September 2004, 06:04 AM   #3
goering's Avatar
sebastien, thanks so much for the info.
Old 15th September 2004, 12:04 PM   #4
Default Re: Can LM317 be used as GC PS regulator?
I wouldn't advise using the 317 as regulator for a GC at full power, perhaps only for a few watts.
For full power you need the regulator to handle at least 3A, like the LM338 or the LT1085.
Using pass transistors to increase the 317 current capacity will solve the problem, but one of the assets of the chip (low impedance) will suffer.
Carlos
Old 15th September 2004, 07:01 PM   #5
I have used the LM317 at 15V with good results !!
Pros (compared to the unregulated version) :
- The soundstage is outstanding
- There seem to be more control in the bass region
Cons :
- There seem to be a little coloration in the sound
You can go up to moderate volumes (enough to wake my neighboorhood up
IMHO these 1 or 2 amp regulators can be used for active speaker projects.
I am planning to try the LM2940 which delivers 1 or 2 amps too ; he seem to have better mesurement...
Has anymone tested it ???
As anyone did tests with low power regulators ???
Yopi
Old 15th September 2004, 08:39 PM   #6
We are talking current capacity here, not voltage. The 317 can handle up to 1A.
Others regulators might be tried, but it's better not to use them at higher volumes, except if they are 3A types.
Carlos
TIP50 + LM317 High Voltage Regulator bee696 Tubes / Valves 11 17th January 2010 04:23 PM
Lm317 Reg geowhitt Parts 2 30th August 2008 08:39 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
LM317 Regulator Problem Bryan Tubes / Valves 12 2nd December 2005 07:37 PM
LM317 current regulator Bas Horneman Tubes / Valves 22 17th January 2003 10:25 PM
Page generated in 0.08007 seconds (80.11% PHP - 19.89% MySQL) with 10 queries
