Old 14th September 2004, 12:21 PM   #1
nbcd is offline nbcd  Romania
Default Stk459 / Stk463
i have a SHARP amplituner that has STK459 as final amp stage with 2x15Watt power and it burned out.Can i replace it with a STK463 whick is rated 2x25Watt ?with no fear that the amp will sound good as before
eugen
Old 14th September 2004, 01:22 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
The pinout looks the same and 99% of the schematic as well.
So, it's worth a try.
Keep in mind however that STK463 needs higher supply rails.
STK459: 2x NF-E, ±31V, 2x>15W(±21V/8ohm)
STK463: 2x NF-E, ±38V, 2x>25W(±26V/8ohm)
I can’t tell you anything about the sound.
/Hugo
Old 14th September 2004, 03:37 PM   #3
Default Re: Stk459 / Stk463
Making a new supply for the new chip may be problematic. Transformer + bigger caps may not be easy to fit in the box you have.
I would stick with the same chip or make a new amp.
Carlos
Old 15th September 2004, 11:38 AM   #4
My voltage rail is about +-24V (not +-27) , can i use this STK463?
eugen
Old 15th September 2004, 11:51 AM   #5
Yes, you can. Power output will be the same as on the 459.
Carlos
How to use STK459 in bridge mode tridibesh Solid State 0 4th June 2005 07:40 AM
Page generated in 0.06986 seconds (82.25% PHP - 17.75% MySQL) with 10 queries
