| Chip Amps Amplifiers based on integrated circuits |
hi all !
I've got the LM3876 (56w) ampli chip. it needs arround 30v, I'd like to know if i can power it by just +30v and GND (without -35v)..... I tried without connectig the -v Pin, but it doesnt work... please help Thanks ! |
#2 | |
Look up for single-supply designs on the datasheet: use those. Carlos E. Martinez |
#3 |
Electrons are yellow and more is better!
RichardA, 30 volts is a bit little. You won't get much power out of it, around 8-9 Vrms only.
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
holy ****....
it have just blown up, all room is now full of smoke Where do you want me to get from +-35v ?!?!?! fortunately I found 2 30v transformers, so i have +-30v... but it just exploded... I think i will try with TDA2004/2003, dont remember... they, at least, work with 12v, so i can supply them up to 50Amps and 300W... Avner |
#5 |
RichardA,
How much experience do you have in doing DIY audio work or in reading schematics? Perhaps you should start with simpler designs that you can set going (amplifying) instead of higher voltage designs. From your mails you don't seem to know what a single supply and dual supply power is, and you may run a higher risk if you got a room full of smoke with this project. Even if burning things up is something that comes with DIY audio, things can get dangerous in some circumstances, particularly with large capacitor exploding. Don't forget to wear safety glasses. Sorry if I sound too paternalistic or exaggerated, but if by this you can avoid some perils it's all for the best. My advice is to start with some nice 12v car amps and learn from that. Get pcbs kits for your projects, don't do point to point wiring until you are well experienced. After a few working projects, go up to the ladder to dual supply amp, and so on. Good luck! Carlos |
#6 |
OK..
Thanks !!! any reccomendation for a chip using only +12v ?? Avner |
#7 |
Find a project with the TDA1553Q or a similar chip.
Carlos |
| LM3876 and 4-ohm drivers | astrodog | Chip Amps | 15 | 2nd July 2008 11:22 PM |
| LM3876 for small sub amp? | phreeky82 | Chip Amps | 11 | 5th July 2006 05:50 PM |
| LM3876 vs. LM3875 | Wynand | Chip Amps | 3 | 12th July 2005 09:03 PM |
| Help with a LM3876 amp! (nOOb) | Fizx | Chip Amps | 3 | 24th June 2005 07:22 PM |
| Lm3876 | bobossa | Chip Amps | 1 | 1st March 2005 04:18 PM |
| Page generated in 0.09618 seconds (73.92% PHP - 26.08% MySQL) with 11 queries |
