Old 13th September 2004, 09:38 AM   #1
b<ben>n is offline b<ben>n  Australia
Default resistor in lm384 datasheet?
hi
there is a resistor on the data sheet for the lm384 that says 2.7 is this 2.7ohms or 2.7kohms.
and can anybody see a problem with using a 470uF cap in the place of the 500uF one. and a 4.7uF in the place of the 5uF as i have some of these allreddy.
Old 13th September 2004, 10:00 AM   #2
Geek's Avatar
No problems. That's called a "Zobel network" and keeps the amp out of trouble with inductive loads at HF or if the load is disconnected.
Old 13th September 2004, 10:01 AM   #3
oh
but is it a 2.7k or 2.7ohm
or is it something compleatly different and not a resistor at all
Old 13th September 2004, 10:14 AM   #4
Geek's Avatar
2.7 ohms.
Old 13th September 2004, 10:19 AM   #5
thanks
why is it so hard to find 2.7ohm resistors
what do u recon will happen if i use a 2.2ohm one?
DAC datasheet zhqazi Analog Line Level 0 29th April 2009 03:03 PM
Which resistor type for emitter resistor? sajti Parts 25 8th April 2009 06:12 AM
What are you using for LM384's? leadbelly Chip Amps 1 10th March 2004 08:15 PM
Datasheet help Stocker Parts 0 10th March 2004 01:36 PM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Page generated in 0.07362 seconds (73.28% PHP - 26.72% MySQL) with 11 queries
