Old 12th September 2004, 07:22 PM   #1
dvdwmth is offline dvdwmth  Canada
Default cap on speaker causing amp to cut out
I just finished assembling my lm3876 amp and I'm very pleased. At first I had it running on a pair of RS 1187s no problem. Sounded amazing. Then I decided to try it with my tang band w3871s' which have a 100uf 100v cap on them and after about 10 seconds the right channel went silent followed by the left a couple of seconds later. The only thing I could think of that was different between the two speakers was the cap on the Tang bands. When I removed it the problem went away.
Aside from this everything is working flawlessly. No hum, just good sound.
Can anyone tell me what is happening here?
This isn't really a big problem at the moment since I dont really listen that loudly and the speaker seems to be surviving without the protective cap, but my next speaker project is going to be a two way and Im worried the crossover will bring about the same problem.
By the way, I am just assuming that it is the amp cutting out. I dont know why else the signal would cut out but perhaps there is another explaination.
Old 12th September 2004, 10:00 PM   #2
markp is offline markp  United States
It sounds like you've got the cap in parallel with the speaker and not in series with it. The amp will shut off if you try to drive a pure capacitor load which is what happens if the cap is in parallel with the driver. Look at how its wired up and if you think its right try putting a 4ohm resistor in series and see if it still turns off.
If it sounds good... it is good!
Linear power supply causing mains hum at speaker cmhadley Power Supplies 5 18th April 2009 02:43 PM
Power trans coupling with speaker, causing hum slowpogo Parts 0 15th January 2007 01:59 AM
OPTs causing crosstalk? blacklight Tubes / Valves 2 28th November 2006 10:49 PM
What's causing that #$%&@$ humm?? sachi Chip Amps 10 9th February 2006 01:29 PM
relay causing oscillation DocP Solid State 7 8th July 2002 04:52 PM
Page generated in 0.09359 seconds (75.52% PHP - 24.48% MySQL) with 10 queries
