Has anyone tried using lm4780 in bridged mode. I wanted to use that configuration for a sub woofer. Wanted a few inputs on how to go about designing the PCB for this configuration.I want to keep this a single layer PCB since its more "diyable"
I am using ExpressPcb
Please help! I am stuck here because I dont know how much space I should allow for the ic pins and how to position the parts.
Thanks.
Thanks.
Look at the thread http://diyaudio.com/forums/showthread.php?s=&threadid=35572
Pavel Dudek vel Upupa Epops has presented his amp based on LM4780 ICs. You can look at his very complicated but flexible PCB.
I made a stereo bridged pair of LM4780 amps.. but I didn't use a PCB, I made it on vero board, .. it doesn't look very pretty, but it works just fine... it's allmost unbelieveble how cheap a stereo 240Watt amp can be made now... 2xlm4780, and couple of resistors... ... I used the circuit of the datasheet, I got less then 20mV offset and it sound pretty good.. It does get warmer though, you may gotta you a significant heatsink..
Goodluck,
Thijs
Goodluck,
Thijs
My agree.
A lot, lot warmer. You'll probably invest more in the heat sink than you would in a printed circuit board. PM me.
- Chip Amps
- Bridged lm4780
