| Chip Amps Amplifiers based on integrated circuits |
If plan to house PS and the AMP in the same unit. How do I sheild a EI transformer.
Also wanted to know if sonics will be very bad if I use a EI transformer. As of now I wanted to test the setup with a EI transformer since I cannot afford a torodial. Thanks in advance |
#2 | |
diyAudio Moderator Emeritus
#3 |
Thanks Bas, but any ideas how to sheild the transformer?
#4 |
Banned
I use aluminium tape.
#5 |
Should I cover the transformer with aluminum tape ??
#6 | |
a.) Shielding the circuitry from the magnetic fields? or b.) Shield the transformer from RFI. In the first case you should get a pre formed mu-metal casing. in case of b.) You could use alu foil or special made copper foil from 3M. The last option (b) won't necessarily give an improvement in sound.. Cheers, Bas |
#7 |
1) Amps using unshielded EI transformers may sound better with the transformer on a different metal box.
2) You may try using a steel plate to separate the supply area from the amp area. 3) You may also try mu-metal tape, but it won't be as effective as 1. Using 2 +3 may prove effective too. Carlos |
| Shielding? | ROBSCIX | Analog Line Level | 7 | 27th October 2006 05:28 PM |
| shielding | tenderland | Solid State | 1 | 27th September 2006 02:00 AM |
| Shielding | Lostcause | Everything Else | 12 | 8th November 2005 02:30 PM |
| Shielding a transformer | SteveG | Parts | 5 | 26th July 2002 04:21 PM |
| Transformer shielding | shadow | Solid State | 11 | 16th May 2002 10:26 PM |
| Page generated in 0.07562 seconds (77.34% PHP - 22.66% MySQL) with 10 queries |
