Old 9th September 2004, 04:13 PM   #1
Devil_H@ck's Avatar
Send a message via ICQ to Devil_H@ck Send a message via AIM to Devil_H@ck Send a message via MSN to Devil_H@ck
Question DRV134 Input Resistor & Opamp Output Questions
I'll be using some DRV134s in my pre for a balanced out and while routing the board today, I checked the datasheet once more just to be sure I didn't make any stupid mistakes.
In the datasheet there isn't any resistor shown on the input of the DRV134, so I suppose it isn't necessary to use one, right? Or would it be safer to add one?
Next question, I can't seem to find an answer for this one. Take a look at the attached image. The opamp on the left controls the gain, the output resistor is to avoid oscillations. But how do I handle the output to the 2 DRVs & 2 opamps (the chips on the right)? Is my scheme with the resistors correct or not?
Website: http://members.lycos.nl/anthonyvh
Old 10th September 2004, 11:19 PM   #2
Devil_H@ck's Avatar
* bump*
No one?
Old 15th September 2004, 04:34 PM   #3
Devil_H@ck's Avatar
Ah, c'mon, 75 read my question and not one of them can help me out?
Think ! Help me !
Old 15th September 2004, 06:15 PM   #4
Default Re: DRV134 Input Resistor & Opamp Output Questions
You should ask several of these questions to TI's support.
You don't need any resistor at the input of the DRV134, but you will need a blocking cap if there's any DC.
Carlos
Old 15th September 2004, 06:45 PM   #5
Devil_H@ck's Avatar
Ok, so no input resistors to the DRVs, thanks!
Are the resistors for the 2 opamps correct? I think they are, but I'm not 100% sure.
Old 15th September 2004, 08:46 PM   #6
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Devil guy,
I looked at your diagram, not sure what you want to do. In both cases I see unbalanced outputs, if you need balanced outputs you must invert one of the pair of outputs. What is in those squares with the + sign?
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 15th September 2004, 09:38 PM   #7
Tim__x is offline Tim__x  Canada
Not sure what the little boxes are (BUF634 perhaps), but I'm pretty sure the big boxes are the DRV134's which are quite nice unbalanced to balanced converters from ti.
Old 15th September 2004, 09:41 PM   #8
Your concept for splitting the signal looks fine to me.
Old 16th September 2004, 12:04 AM   #9
Devil_H@ck's Avatar
janneman, Tim_x got it right, the small boxes with the + sign in it are BUF634s, the big boxes are DRV134s. I left out the values to make the schematic easier to read.
Thx, Tim_x .
* Oh, btw, I believe there is a flaw in that schematic, I've changed it in the version on my PC. The JFET biassing cascode should be after the BUF634, on the output, since that's where the feedback to the opamp is taken.
Old 16th September 2004, 02:57 AM   #10
The purpose of the cascode is to draw a constant current from the output devices in your opamp, so unless you want to bias your BUF634's into class A they should be right on the opamp output.
Questions on BB1794 and AD1865 input to Rudolf Broertjes' and Pass D1 output stages Jolojl Digital Source 0 14th April 2008 10:25 PM
Opamp output resistor.. jethdub Chip Amps 3 21st January 2008 03:46 PM
Input / Output impedance, Resistor network Vs. Dynamics -_nando-_ Everything Else 3 24th March 2007 11:19 PM
Input buffer for DRV134 Mrpong Chip Amps 18 9th September 2006 01:19 AM
Tube differential input/buffer /w opamp output gainclone aletheian Chip Amps 2 23rd August 2005 07:36 AM
Page generated in 0.10377 seconds (80.22% PHP - 19.78% MySQL) with 11 queries
