Old 10th September 2004, 05:15 AM   #11
ingrast is offline ingrast  Uruguay
Some notes:
You will need a +/- 28 VDC supply in the 500W class to get the full rated 270W (8 ohm load for both channels).
You may either select lower voltage supplies down to +/- 15 with reduced power output.
You can also choose to not install U2 and U4 for example, and connect the loads from X2-1 and X2-3 to ground instead of X2-2 and X2-4 respectively. In this case you will have half the output capability for each channel.
Of course other arrangements are possible also.
Good luck and enjoy!
Rodolfo
Old 10th September 2004, 01:45 PM   #12
Aharon is offline Aharon  Canada
Thanks Rodolfo!!!
Aharon
Old 11th September 2004, 02:09 AM   #13
Originally posted by bigparsnip
I think sound nerd built the one I finaly posted and it worked well, so that could be a starting point although I'm not sure about the others which could work too).
yep. I did.
Worked excellent.
Here it is on my website, scaled for printing:
http://www.aloofhosting.com/electron...ers/lm3886.htm
I still need to upload the schematic.
Old 26th May 2009, 01:58 PM   #14
suds is offline suds  India
Hi..
I am working on LM3886 Amp..!
Would anybody need PCB (LM3886 Amps, PSU), let me know.
Or if you need PCB for you own design, custom design.. I would be able to help on this too.. !
sudhirmt@gmail.com
~suds~
Old 5th August 2009, 04:11 PM   #15
Send a message via MSN to petrusevski Send a message via Yahoo to petrusevski
Originally posted by suds
Hi..
sudhirmt@gmail.com
Can you post the PCB designs here please?
Class D Amp Request... mehrdad Class D 5 4th June 2007 10:54 AM
Request for 5 NSB's eddog Multi-Way 9 2nd February 2006 01:17 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Page generated in 0.07762 seconds (70.67% PHP - 29.33% MySQL) with 11 queries
