| Chip Amps Amplifiers based on integrated circuits |
#301 | |
Thanks... |
#302 |
Don't hold your breath Rich. The poster is now involved with commercial hi-fi and hardly ever posts on the DIY forums.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#303 |
So how about TDK? Or Did I miss it in the shuffle?
#304 |
Hello!
I just found a store (online, called Banzai Music), located in Berlin, Germany, who sells some PEC carbon pots of MIL-STE series. They offer values of 1kohm, 5kohm, 10kohm and so on, log. Now I'm asking myself the folloing question: Wouldn't it be the best thing to go for a source with a really low output impedance (e.g. below 100 ohms), then add a 5 kohm pot, and then a power amp with a rather highish input impedance, say, something around 30 kohms? I mean, wouldn't this be the best way to really avoid any active pre or buffer stage, without the usual drawbacks of a passive pre? Please guys, let me know what you are thinking about that! The PEC stereo pots cost 47,30 Euro each, so I have to decide carefully which value might be the right one in my case. Thanks! martin |
#305 |
Passive Aggressive
I would buy your PEC pots elsewhere. Thats a huge amount of money for them. www.tubesandmore.com sells them, single pot not stereo, for 6.60USD each. I imagine after buying two, paying shipping and duty fees you would be way cheaper than buying that stereo pot.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#306 | |
The problem with stereo PEC pots is poor channel matching. I had pots that had 6db tracking mismatch between channels and were completely useless for audio.
So while I was quite excited about them initially, I completely abondoned them later. If you buy 5 of them, chances are you'll find one with pretty good tolerance though ![]() Using single, preferrably linear pots, solves this problem and you can source them cheaply from DigiKey, however two separate pots for frequent volume adjustment are very unpractical. Quote:
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#307 |
Hi udailey, Hi Peter,
thanks for your answers! The problem is, that there are not many pots available that have such a low impedance value like 5kohm. Usually the whole thing starts at 10kohms and up. I really don't like the idea of heaving two mono pots, so I guess I'll have to go for something else here. And I totally agree: I was shocked about the prices for the PEC pots! But ok then, perhaps a TKD stereo 10kohm pot will also do the job, I'll try. Regards - martin |
#308 |
I never tried TKD, although heard good comments about it.
Another option would be building your own discrete attenuator.
#309 |
BTW, there is a second part to this thread: In search of a perfect attenuator
| Potentiometers - USA | Brit01 | Tubes / Valves | 8 | 8th August 2009 12:14 AM |
| potentiometers | zahlm | Parts | 1 | 15th April 2004 05:43 AM |
| Potentiometers | slogan2112 | Solid State | 2 | 19th December 2003 06:54 AM |
| Page generated in 0.09239 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
