Old 9th September 2004, 01:07 PM   #1
Lynxz is offline Lynxz  Netherlands
Default Multichannel GC: choosing rectifying bridges
Currently I'm working on a 6-channel GC using the kits from BrianGT.
I have one 1000VA center tapped transformer. Close inspection of this beast revealed it actually has two secondoraries so modifying it in order to make it a dual secondary one should be possible.
Now I have to choose from the following options:
a) make the trafo a dual secondary one and build three dual bridges using the MUR860 diodes. ('normal' GC kit approach)
b) leave the trafo as is and build six single bridges using the MUR860 diodes. ('normal' center tap approach)
c) modify the trafo and use a dual bridge (in metal casing)
d) use one single bridge (in metal casing)
e) ...other suggestions?
What's the best thing to do? What will sound better? (is there any difference at all?) Six single rectifier bridges or three dual ones?
Rectifying Diodes 4007s Stryker11487 Solid State 4 6th June 2009 02:02 PM
Rectifying Heater Supply AmpBuilder225 Tubes / Valves 2 7th April 2009 07:35 PM
Rectifying multiple secondaries.. DigitalJunkie Power Supplies 6 15th February 2009 03:26 AM
Using discrete diodes instead of rectifying bridges. Peter Daniel Solid State 23 4th September 2002 06:27 PM
rectifying....what would be prefered (aleph PS) hifi Pass Labs 12 20th October 2001 10:34 PM
Page generated in 0.06355 seconds (66.57% PHP - 33.43% MySQL) with 10 queries
