Old 9th September 2004, 09:12 AM   #1
polsol is offline polsol  South Africa
Default OPAMP with Transistor Output
Anyone any recomendations for a power amp using low power op-amps driving conventional transistor)s) output stage?
Links to any available designs would be much appreciated.
Tony M
Old 9th September 2004, 10:24 AM   #2
mik is offline mik
http://audio.lukar.net/forum_wpisy.h...mat=5755&all=1
http://shell.sinuspl.net/~igod/pdf.zip_ password is abcd1
Old 9th September 2004, 11:08 AM   #3
mandat is offline mandat  Poland
Here you are the recent address of this forum.
http://www.audiostereo.pl/forum_wpis...mat=5755&p=5#k
When you want to know another projects of this author press the links below.
http://www.q-audio.pl/
http://q-audio.dis.pl/gallery/
Old 9th September 2004, 11:29 AM   #4
li_gangyi's Avatar
maybe you guys read the question wrongly...but he wanted BJTs as outputs...not MOSfets...hmmm but it does seem interesting though...there were some posts by Circltron on Current damping afterburners on Power opamps...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 9th September 2004, 11:44 AM   #5
>li_gangyi
Hey Mr, look at the gallery and you find such a project, too.
Old 9th September 2004, 12:08 PM   #6
li_gangyi's Avatar
since we're on this topic...I wanted to ask if there is any possibility of power outputs of over 200W...into 4 ohms that is...using this kinda configuration...
Old 9th September 2004, 02:13 PM   #7
Specification of the amp mentioned by mik.
PSU: +/- 28V,
gain: +41V/V
load: 4 Ohm
quiscent current:120mA
THD+N: 0.008% (22Hz to 22kHz, P =1 to 10W)
THD+N: 0.014% (22Hz to 22kHz, P = 11 to 40 W)
THD+N: 0.6% (22Hz to 22kHz, P = 41 to 75W)
SR: +22/-18V/us
About a specification of other amps from mentioned gallery you should mail to dariuszkulesza@wp.pl
Old 11th September 2004, 05:39 AM   #8
Thanks for the info. Unfortunately i don't speak Polish but have still managed to glean some info.
I have also found an Amp on the ESP site plus "Op-Amp Boosters" are also covered in an application note on the National Semiconductor site plus I found an old JLH reference in his articles in ETI 1986 (from memory).
As for power output, this is limited by the drive capability of the opamp (available output current and voltage swing) i would imagine.
The reason for looking into this aspect of amp design is that I'm not too happy with trying to use a "one chip" power amp as i don't think that the thermal properties of the chip/heat sink would be too good and BJT's should be better. Also using a "front end" of known characteristics allows one to then look at the ouput current gain topology more closely.
Tony M
Old 8th February 2007, 02:47 PM   #9
tino96 is offline tino96  Italy
damn.. q-audio links are both dead....
I've found new realase of project.
unfortunately I don't speak Polish...
someone have info, PCB and docs about this very interesting project?
Old 8th February 2007, 03:56 PM   #10
re-arranged...: good http://forum.akustyka.info/viewtopic...hlight=drakula
Can bias transistor mount on top(body) of output transistor?? Leolabs Solid State 23 16th February 2008 12:35 AM
Opamp with transistor output linearity vossie Pass Labs 3 10th November 2004 07:40 AM
Transistor/opamp circuit soundNERD Chip Amps 12 15th September 2004 02:16 AM
ALL TRANSISTOR OpAmp Samuel Jayaraj Solid State 15 10th August 2004 02:23 PM
Page generated in 0.08913 seconds (87.44% PHP - 12.56% MySQL) with 11 queries
