| Chip Amps Amplifiers based on integrated circuits |
#441 | |
Glad to hear I am not the only one Well a lot was learned in the troubleshooting. It all wound up to something like this: The noise on the outputs were caused be the rectifier bridge. I replaced it with a P2P rectifier. After that, the amp was completely silent! Except for music, to the relief of some people I tried pretty much to change everything else in advance of that. Then I added a pair of 3.3uF mkp's to the inputs, and then there was a faint hiss! I am sure the big MKP's acts as some kind of antennae, picking up noise! What are you people using for input caps? I need them, since all kind of sources wil be connected to the amp, PC, discman and so on.Steen. |
#442 |
Apologies if this subject has been raised earlier in the thread ( I have only read the beginning and the end), but are you aware that use of the T-network reduces the bandwidth of the amp?
My simulations (with an OPA604) show a reduction in bandwidth from >200KHz with "normal" feedback to about 60KHz using the T-Network with Franz's values (47K, 18K, 18K, 150R). I suspect these figures will be lower with a power op-amp like the 3886. Is this intended? |
#443 | |
Steen, when you added the input cap, did you change the grounding of the input/cable/plug? What happens when you ground the input pin of the input cap? You experiences with the rect point to ground loop hum/hiss. The fact that it now comes back may have the same cause. Jan Didden
/Another new issue: Linear Audio Volume 3! |
#444 | |
Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#445 | |
The point is that nobody seems to want to investigate the AC performance of their LM3886 implementations. All I see is endless ramblings about the (not particularly relevant) dc performance! |
#446 | |
Since the chip is internally compensated (the dominant AC characteristic) when gain is = 90 ninety then the open loop becomes equal or lower around 70KHz, hence no more feedback. Must have the layout right, grounding etc perfect, as PSRR at high frequencies is now poor, but good layout should prevent buzzes. Less feedback mean less slew rate induced distortion. This happen at HF where the feedback cannot quite keep up. But no feedback means slewing can't happen above 70KHz. Does it sound better? Try and see for yourself. Joe R.
#447 |
Hi Joe,
I think it might be a bit more complex.... http://www.springerlink.com/content/...3/fulltext.pdf Cheers, Dave |
#448 |
but Joe likes less bandwidth ..
#449 | |
Joe R.
#450 | |
Joe R.
| Oscillation due to (probably) feedback network | Mambo | Solid State | 21 | 6th November 2007 02:49 PM |
| Purpose for RC network on Feedback | corrieb | Solid State | 8 | 10th January 2007 07:23 AM |
| how do you design a class d feedback network? | Randy Knutson | Solid State | 3 | 30th August 2003 06:00 AM |
| Feedback network silences op-amp resistor noise | mrfeedback | Solid State | 0 | 5th April 2003 12:06 PM |
| Page generated in 0.11946 seconds (85.15% PHP - 14.85% MySQL) with 11 queries |
