| Chip Amps Amplifiers based on integrated circuits |
#31 |
Well, I forgot to get the link at work the other day and it seems people have been buisy in my absence (which is always interesting). anyway, I have included the link to the application note below for those who are interested, and although it is technicaly describing transimpedance amplifiers, you only need and one extra resistor to the circuit to get you NIGC configuration.
http://focus.ti.com/lit/an/sboa060/sboa060.pdf |
#32 | |
Example: You read 1.2mV, then 0.0012 devide 1000000 = 0.0000000012A or 1.2uA or 120pA. Next you do exactly the same across the other 1M connected from (-) input to output pin. This is now the (-) Input (Bias) current. Ideally they should measure exactly the same, if they do you will have zero Input Offset current. The latter is the difference between the two. So if you have 120pA on one and 100pA on the other, the offset is 20pA. or 0.020uA Finally the Input Offset voltage is the voltage across (+) and (-) in mV. Knowing this, you can do what I did and post the results here. The perfect chip will have the same input current (balanced) and hence zero offset current. It will also have zero voltage across (+) and (-) pins/inputs. A chip like that would also have zero DC Offset on the output if the R values are the same, whether 1M or whatever. Is there one out there? Well, we can all dream. Have a go. Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#33 |
Banned
It would be nice to match two chips before using them on a circuit...
#34 | |
#35 |
I had a related experience in a feedback cct not on a GainClone but a single mosfet x10 voltage amplifying stage. Initially I had a feedback resistor of 3M3 and an input resistor of 330k. It worked but wasn't great. *BIG* improvement when I reduced both resistors by a factor of 10. Seems the nonlinear gate capacitance with signal voltage was making a visually noticeable amount of distortion on the 'scope.
The voltage swing on the virtual earth summing junction, the "-" input of a chip amp would be very low by comparison with my mosfet gate, but you never know...
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#36 | |
At a first glance you are OK, but, please think twice! I've had your same think but I proved myself I was wrong. I already knew the AppNote What you state is correct for transimpedance amplifier with a current at the input NOT for a voltage amplifier (inverting or non inverting). In the case of voltage amplifier the voltage gain is proportional to the RATIO of two or more resistors NOT their absolute value. The noise instead is proportional to the square root of the value of the resistor. So you maximize the signal to noise ratio (in voltage amplifier) lowering the absolute value of the resistors. Hint: there is a very special case in which T feedback is NOT the best solution in voltage amplifier: do you guess? |
#37 | ||
I’d say the rest of feedback made of 100R and 10k, plus 22k series input, and 10k shunt at + input is fine both to keep relatively similar impedances at the inputs and modest DC offset. These values may be good either for tube or solid state buffers or no buffers at all. As a final result, I doubt the offset at the output will come higher than 50mV. Though it will vary below this point more than we accustomed to have using a conventional feedback. So, if it does, everything is under control. Pedja |
#38 |
Not elegant, but if all else fails, or for out of spec chips, this can be done:
http://www.diyaudio.com/forums/showt...317#post449317 Sheldon Pedja, with a 22k input resistor, would you recalculate your LP recommendations or not? |
#39 | |
if only it could be used for good, not evil... |
#40 | |
It is simlar to the NIGC. The impedance here is mainly determined by the first series resistor. This 22k instead of 10k will shift the slope a bit down, and to keep the previous slope you may use somewhat lower value for the first resistor. Something like 900R instead of 1k will be fine. Pedja |
| Oscillation due to (probably) feedback network | Mambo | Solid State | 21 | 6th November 2007 02:49 PM |
| Purpose for RC network on Feedback | corrieb | Solid State | 8 | 10th January 2007 07:23 AM |
| how do you design a class d feedback network? | Randy Knutson | Solid State | 3 | 30th August 2003 06:00 AM |
| Feedback network silences op-amp resistor noise | mrfeedback | Solid State | 0 | 5th April 2003 12:06 PM |
| Page generated in 0.12838 seconds (83.70% PHP - 16.30% MySQL) with 11 queries |
