| Chip Amps Amplifiers based on integrated circuits |
#361 |
Franz, do you mean, that by inverting mode is on + input only DC bias current without any fluctuations ? If both inputs are working by the same conditions ( AC and DC ), theoreticaly, but practicaly also, is in this case distortion lowest, 'cos all is balanced.
#362 | |
Banned
Franz, distortion you can measure, but do a favour to yourself: try a 220k resistor from NI to ground and tell me you you listen to noise or not. Hiss. LOUD AND CLEAR. |
#363 | |
The new info is that the problem does not occur if the buffer is not connected when the main ps is turned on (remember the buffer is always on, ala Joe R's tube buffer). If I turn on the ps and then connect the buffer, it acts normally. The offset is even a little lower. If I mute the amp during turn on, no problem. I had thought it unnecessary, at least for the turn on thump. Not so, at least with this chip. Some sort of weird latch up (one one channel only and only with one of the buffers) if the buffer is on while the amp turns on. Back to see what I can do with the NE555 and a relay. Sheldon |
#364 | |
Franz |
#365 | |
Banned
Of course you don't want that. You can use 22k, still a low value. And you will have matched impedances. |
#366 | |
Sheldon |
#367 |
From my last assumption, it's correct. After I removed the volume out and made the amplifier to be audio power amplifier, it can now sing a song.
without any noise. I thought T-network amplifier is as well as non inverting amplifier after my testing. I like its sound. |
#368 | |
Do you have a cool room? Then I could come "ti nai krungtheep" to listen to your setup !Sawadee Franz P.S. My youngest daughter, 6 years old, is speaking swiss german and thai. |
#369 |
Sawasdee Krub,
"Ti Nai Krungthep" is mean "Where is Bangkok?" but for correct word, you should say " Krungthep Yoo Ti Nai".I don't have a cool room in my home but at the future I will. I planned to modify my amplifier by changing some R values and some capacitors. I will change some R values like Carlos because Gaincard input impedance is 22k, however, I must calculate new three feedback resistors again to match with the new input impedance. So I must change the DC coupling capacitor from 4.7uF to maybe 2.2uF. Will it be good idea?
#370 |
I am a farang and with
"Ti Nai Krungthep" is mean "Where is Bangkok?" I wanted to say: I could come to Bangkok and visit you to check your gainclone quality. Lowering the value from the coupling cap will always be a good idea, (at least, as it is easier to buy good quality caps with lower values) as far as you dont have a too high rolloff frequency from the resulting HPF together with the following input Z. Regards Franz |
| Oscillation due to (probably) feedback network | Mambo | Solid State | 21 | 6th November 2007 02:49 PM |
| Purpose for RC network on Feedback | corrieb | Solid State | 8 | 10th January 2007 07:23 AM |
| how do you design a class d feedback network? | Randy Knutson | Solid State | 3 | 30th August 2003 06:00 AM |
| Feedback network silences op-amp resistor noise | mrfeedback | Solid State | 0 | 5th April 2003 12:06 PM |
| Page generated in 0.14835 seconds (67.98% PHP - 32.02% MySQL) with 11 queries |
