| Chip Amps Amplifiers based on integrated circuits |
#21 |
i've built one of these amps last year. i had a post about it but no pics. i called it the HI3GC -- high input impedance inverting gainclone.
used as a woofer amp. pros to design: 1.) small feedback cap. 2.) stable, it worked fine. cons: 1.) increased DC offset (70mV for what should be equal input biases). this was on a bridged design, but the dc offset was overall higher then the non-HI3GC 2.) more parts 3.) you can get more dependence on tolerances. this was on a lm4780, so i'd suspect chip difference should have been low...
if only it could be used for good, not evil... |
#22 | |
Banned
After all, it's a 2-channel chip. But the resulting DC-offset still varies from chip to chip. |
#23 | |
Banned
With valve buffer. |
#24 | |
If retaining that 10K but increasing 100R to 220R (staying with standard values), now increase the other 10K to 22K, retain the 22K input Z (or similarly 18K + 4K7 with the standard tube buffer with LPF), then 22K on (+) input to ground. This should pretty much halve the potential DC Offset so that rarely should go higher than 25mV? Should work. This will remove further any need to null, and besides nulling is not desirable in Terry's view and I'm coming around to that view as well. For other DIY'ourselfers who wish to assemble this, or update their amps to T-Network, we need to guide them and give them a set of fixed values that works. So my revised suggestion is, 22K input Z, then 22K to 220R which is grounded, then to 10K to output, Matching 22K on (+) is 1% near ideal target 22K2. Gain is in the mid-fourties. The ideal 22K2 results from 10K/220R in parallel = 218R plus 22K in series = 22K2 rounded. This will balance both 'R' and 'C' and reasonably low DC Offset. I will also post a revised schematic so the above will be clearer for everyone. Joe R.
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#25 |
Yikes!
That didn't work out, went from +38mV to +52mV - back to the drawing board - in the meantime stay with earlier values.
#26 | |
i'mm have to go home and find out what resistors i used. i think there was a 330 ohm in there somewhere. i remeber the values all lines up fairly well.
#27 | |
The best sounding IGC I have has DC offset of around 50mV on one channel and around 30mV on the other. Full marks to Joe for trying to make this available to those of us without the technical understanding, a policy that I have always tried to adhere to with Decibel Dungeon. I for one, greatly appreciate his attitude! "IT IS THE FRUIT THAT MAKES THE TREE BOW LOW."
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#28 |
OK, while many of our Euro Brethren still have their heads on pillows, I have been a busy bee.
I now know why the last one blew out from 38mV to 52mV. This particular chip has significant more Input Offset current - so increasing to 22K that became the dominant factor. Let's examine four different chips: One: (+) Input Current = 0.105uA (-) Input Current = 0.150uA Input Offset Current = 0.045uA **** very high - not within spec Input Offset Voltage = 3.1mV **** not typical DC Offset = 38mV Two: (+) Input Current = 0.080uA (-) Input Current = 0.072uA Input Offset Current = 0.008uA **** very good Input Offset Voltage = 0.1mV DC Offset = 8mV Three: (+) Input Current = 0.080uA (-) Input Current = 0.080uA Input Offset Current = zero **** perfect Input Offset Voltage = 0.1mV DC Offset = 6mV Four: (+) Input Current = 0.100uA (-) Input Current = 0.080uA Input Offset Current = 0.020uA Input Offset Voltage = 0.5mV DC Offset = 26mV Look at the data sheeet One is not within spec on Input Offset current, and 3.1mV Offset voltage is not typical (1mV) but within max (10mV). I say this because I believe One is not typical overall. All above vere 10K/100R/10K & 10K on (+). Now changing this to 22K/220R/10K (on output) & 22K on (+), got the following result: One: Went up from 38mV to 52mV - affected by Input Offset Current and voltage - but more suspicion re current. Two: Went down from 8mV to 4mV - the reduction because Offset current is low. So is Offset voltage. So using 10K/100R/10K & 10K on (+), is better able to deal with Input Offset current. Whereas 22K/220R/10K (on output) & 22K reduces DC Offset on the main output only if Input Offset current is reasonable or typical. There there is a point where going for better than 100:1 ratio down to 46:1 ratio ought to be better and usually is, but in the, hopefully only occasional chip, the imbalance in the input currents swamps the advantage because we end up using 22K - the higher Z becomes a disadvantage. WHEW! Wake up guys... awaiting feedback. Joe R.
#29 | |
Seriously, while I think of it, I also want to thank Terry Demol for picking his brains. Joe R.
#30 |
I'm awake and listening Joe (I am still partly on Laverton time despite the 24 year gap
).For a newbie, how do you measure the chip to see if it is within spec? Is it as simple as placing a meter in series with each input and reading the current?
| Oscillation due to (probably) feedback network | Mambo | Solid State | 21 | 6th November 2007 03:49 PM |
| Purpose for RC network on Feedback | corrieb | Solid State | 8 | 10th January 2007 08:23 AM |
| how do you design a class d feedback network? | Randy Knutson | Solid State | 3 | 30th August 2003 07:00 AM |
| Feedback network silences op-amp resistor noise | mrfeedback | Solid State | 0 | 5th April 2003 01:06 PM |
| Page generated in 0.14716 seconds (83.24% PHP - 16.76% MySQL) with 11 queries |
