Old 9th September 2004, 04:25 AM   #1
dvdwmth is offline dvdwmth  Canada
Default Can someone explain this tranformer?
I am reposting this from another thread because its important I get this question answered before I carry on with my project.
I had mistakenly been using an over powered transformer in my last project and I'm now building an lm3876 Amp that I need a new power supply for.
I went to the surplus store and spotted a couple of 24V 75VA transformers and figured they'd do the trick.
I've just unpacked them and now I see there are three primary wires . They are labelled:
120 V 1-------------)
95 V 2-------------)
0 V 3-------------)
the label says
PRI 95/120, 60Hz
SEC 24V, 75VA
So why are there three primaries. Im hoping that this is a supply for EITHER 95V or 120V and that I can just connect the appropriate wire, but I'm not going to assume that.
Can I use this thing or do I have to go buy yet another pair or transformers.
Old 9th September 2004, 05:19 AM   #2
It is exactly how you assumed: You'll have to connect 3 and 2 for 95 Volts or 3 and 1 vor 120 Valts and you'll be happy !
Charles
BTW: Where, for heaven's sake, is 95 Volts used ?
Old 9th September 2004, 06:04 AM   #3
runebivrin's Avatar
Send a message via MSN to runebivrin
On the far end of a really bad power distribution line?
Rune
Do wizards use spell checkers?
Old 9th September 2004, 06:09 AM   #4
JojoD818's Avatar
Your replies make me laugh literally.
Old 9th September 2004, 07:33 AM   #5
Thats a relief.
Im started to collect a bit of a pile of transformers that didn't work out for some reason or another.
I wondered exactly the same thing about the 95V.
Old 9th September 2004, 08:03 AM   #6
The answer from our friend from the Philipines leads to the assumption that mains voltages below 100 volts are (unintentionally ?) used there.
Charles
Toasted PW tranformer? whitelabrat Tubes / Valves 16 2nd January 2008 01:42 PM
need power tranformer ideas luthierwnc Tubes / Valves 8 18th December 2007 08:38 AM
Step down tranformer jkeny Everything Else 2 18th October 2005 12:14 AM
Tranformer question CPX Parts 3 7th February 2005 07:44 PM
Torodial Tranformer Calculation JanDH Parts 34 28th December 2003 02:34 PM
Page generated in 0.07953 seconds (74.03% PHP - 25.97% MySQL) with 10 queries
