Old 8th September 2004, 02:33 PM   #1
MWP is offline MWP  Australia
Default It works (DAC + Bridged Gainclone)!
I know there are lots of these "success" threads, but this amp is a little different
As far as i can tell so far, it works perfectly.
Now i just have to build another 2 of them (i need 6 channels for active xovers).
There are two audio channels on this board each using:
SPDIF-IN -> DIR1703 -> PCM1798 -> 2*OPA627 -> 2*LM3886 (bridged)
Schematic here:
http://www.overclockers.com.au/~mwp/...p-dac-amp1.pdf
Yay
Old 8th September 2004, 03:17 PM   #2
Banned
MWP, does the DIR1703 work fine?
With different sample rates?
It seams that the DIRs had a problem and TI took them out, no DIRs anymore.
Old 8th September 2004, 04:00 PM   #3
It works fine with 44.1 and 48Khz without a reset between the change.
I tried with 96Khz which didnt work, but thats probably beacuse of the cheapie optical recievers im using.
Im glad i have a bit of a stash of DIR1703's here
Old 8th September 2004, 04:03 PM   #4
Wow.
This dac/amp sounds pretty damn good.
A little 50Hz hum on one of the channels, but that should be easily fixed.
The other channel is 100% quiet with no audio... exactly what im after since i sit under 1 meter from my speakers.
Old 9th September 2004, 03:09 AM   #5
thomas997's Avatar
wow looks good.
How much was the approximate cost for all that?
You should sell some
Old 9th September 2004, 09:37 AM   #6
Building the full amp (3 of those PCBs, 3*300VA torids, 19" 3U case, misc stuff) has cost me ~$800AU (~$550US).
My LM3886 GainClone almost works! Big Pete Chip Amps 3 9th August 2005 07:11 PM
DAC + bridged gainclone idea... MWP Chip Amps 10 23rd July 2004 05:18 AM
i can't believe this works (baby's first gainclone?) travis Chip Amps 10 9th July 2003 04:18 AM
Bridged Gainclone? 2Bak Chip Amps 4 22nd February 2003 06:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
