Old 8th September 2004, 05:34 AM   #1
Jye is offline Jye  Australia
Jye's Avatar
Unhappy +/- Power supply
hello,
I have a 24V DC 1A regulated power supply and when I have it hooked up to a bread board with 2 1k resistors in series between the inputs and the middle hooked up to earth I get +\- 12V. But when I connect the rails to the active filter they change to -7V and +14V Has this happened to anyone before or does anyone have an idea on what maybe happening?
Cheers
Jye
Old 8th September 2004, 05:40 AM   #2
Bill Fitzpatrick's Avatar
Did you buy that power supply thinking you would have a good supply for the active filter? Where is the schematic of the filter for us to look at?
Old 8th September 2004, 07:12 AM   #3
Jye's Avatar
Hi Bill
No, I all ready had the power supply.
The active filter is just the 12 dB/oct Linkwitz-Riley crossover with the buffer stage.
Cheers
Jye
Old 8th September 2004, 07:21 AM   #4
Tim__x is offline Tim__x  Canada
The problem is that your "ground" is a rather high impedance, buffer it with an opamp in unity gain, non-inverting mode.
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 24th April 2011 12:48 AM
LTspice tool for power amp power supply component evaluation andy_c Software Tools 2 23rd August 2009 06:10 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 05:36 AM
selling high current power supply for power amps. ericpeters Swap Meet 0 14th January 2005 03:21 PM
heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? jarthel Tubes / Valves 10 21st July 2003 02:30 PM
Page generated in 0.08042 seconds (69.38% PHP - 30.62% MySQL) with 10 queries
