| Chip Amps Amplifiers based on integrated circuits |
Hi all,
Im going to start building my new amp tomorrow and am trying to work out what total capacity of PSU smoothing caps ill need. Ill be using 3 * 300VA 25-0-25 torids (=900VA total) to power 6 channels of 2 * LM3886s bridged per channel. Is the general rule in here of 2*1000uF caps per amp IC (=24,000uF total in this case) enough? Or will i be needing more than this? Thanks. |
#2 |
If some of those channels are just supplying a bass speaker or sub, then you could add something like 2 x 10,000 uF for those channels.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
Hmmm, ok.
Well ive got 2*470uF on each amp IC on the PCB already. So, say another 22,000uF on each rail would do it? |
#4 | |
| Help sizing psu smoothing cap | riotubes | Parts | 5 | 8th July 2009 08:07 PM |
| Smoothing Cap: ESR or Capacitance | kptseng | Solid State | 2 | 23rd February 2008 06:23 PM |
| Problem building a power supply, no output after smoothing caps? | markiemrboo | Parts | 11 | 15th January 2007 06:10 PM |
| Oops squashed my smoothing caps!! | Beggar | Parts | 1 | 6th September 2003 10:43 AM |
| HV smoothing capacitors | DeXXSter | Tubes / Valves | 8 | 11th December 2001 11:10 PM |
| Page generated in 0.08269 seconds (67.51% PHP - 32.49% MySQL) with 10 queries |
