Old 5th September 2004, 05:56 PM   #1
pete.a is offline pete.a  United Kingdom
pete.a's Avatar
Default Buffer Fault
Iv'e been making the Carlos buffer, and during testing found the pos reg getting very hot ? Only happens when connected to the buffer, and i think i may have contributed to it when my dvmeter was on the wrong setting...durrr.
When opperating found a difference at the output when no signal applied, 0.700mv left and .0330mv right..wonder if something is mismatched. Put an audio signal from my MD player and all soundedwell on both channels into a pair of headphone's. Just that reg fault, any ideas anyone..will change the opams and buffer's at some time this week, but ive ran out of time now due to parent hood !
Old 5th September 2004, 09:34 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
What voltages are we talking about here Pete? IOW - how many volts are droped across your regulators?
I doubt having your meter set to the wrong range has done any damage.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 6th September 2004, 05:05 PM   #3
pete.a's Avatar
Default Voltages
Hi Nick,
Tx is a 18v dual secondary , so its kicks out around 22v or there about. So were only looking at 7v to drop , but i can't think why that pos reg is getting so hot , to the point where it hurts to touch ! But the buffer still works ok, or so it would seem
Old 6th September 2004, 05:10 PM   #4
Nuuk's Avatar
Neither can I then Pete if it only drops 7 volts.
Is there anybody more knowledgeable that can suggest a reason?
Old 6th September 2004, 05:51 PM   #5
Banned
Hi Pete,
Some questions to see if we can help:
1. What op-amps are you using with the BUF634?
2. At what gain?
3. What voltage do you have before and after each reg, under load?
4. Check the polarity of all the electrolythic caps.
5. Do you have a cap immediately before and after each reg (close to it)?
6. What regulators are you using? For LM317/337, check the orientation of the protection diodes (if any).
Old 6th September 2004, 06:45 PM   #6
Nuuk's Avatar
Carlos - you forgot his inside leg measurment!
Old 6th September 2004, 07:12 PM   #7
pete.a's Avatar
Default Q and A
Hi Carlos,
Op amps are 627 , and iv'e used your design. The voltage before the regs is around 22v and after is , 17v neg and 13v pos , under no load, under load its 14.99neg and 14.97 pos. All the caps are correctly orientated and the regs are the 1a / 15v fixed aka lm7815 and lm7915.
Just one thing Carlos what voltage did you get on the output of your audio buffer , was it around 300mv dc ? this would be at idle no signal....
Nick ..just for you..33inside and 34 waist 5" 10 and 13st..of pure power...
Old 6th September 2004, 08:29 PM   #8
Default Re: Q and A
Is that DC offset, that is at the output of the BUF634? You shouldn't have that high a value, only a few mV.
Carlos
Old 6th September 2004, 10:07 PM   #9
Nuuk's Avatar
I suggest you do less hi-fi DIY and more jogging!
Old 6th September 2004, 10:14 PM   #10
Banned
Default Re: Q and A
There's something very wrong there.
After the regs you should have the same voltage, loaded or not loaded.
It's a regulated PSU...
You have less voltage not loaded?
0.2mv one channel and 0.3mv the other one.
Wait...
Check the pinout of the regs!
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 02:46 PM
Pre amp fault Addolff Parts 4 6th January 2008 02:55 PM
Quad 306 fault steevo Solid State 1 19th May 2007 06:27 PM
What to do? DVD laser fault. richie00boy Digital Source 1 26th January 2006 02:33 PM
Opamp + buffer, how to bypass buffer at HF for unity gain? Christer Solid State 10 29th October 2003 07:50 AM
Page generated in 0.11903 seconds (83.11% PHP - 16.89% MySQL) with 11 queries
