| Chip Amps Amplifiers based on integrated circuits |
#11 |
Some of the 78XX/79XX (depends on manufacturer) exhibit strange behavior: under no load they supply more voltage than Vref. For example not mentioned Korean producer made 7805 with some 7V output under no load. When loaded everything was fine, 5V. The cure was to use load resistor at the output of the regulator to assure load current at least 5mA (i.e. 1kOhm resistor for 5V regulator).
And - do you have center point (0V) defined?. |
#12 |
Banned
Pavel, he has less voltage under no load than connected to the circuit.
#13 |
Iv'e scrapped the whole build ! I couldnt find out what was going on in that little circuit.
I may try building the heaphone amp just using one op amp as per Carlos design, as i feel thats where i went wrong using zero links for different connections ! between op amps and buffer chips. As i only had limited time to construct this project i may have overlooked a connection ..who knows..it happens. But thanks for the help guys. Carlos..regs gave out 14.98v under load and 18v off load until the circuit went ...Pop ! Pavel do have any pcb graphics for the head amp, as i have a friend how will make a pcb, but isn't that good at pcb design. Has the equipment but not the electronic discpline. |
#14 |
Pete,
probably I would release a PCB artwork for audio buffer, that can be used as a headphone amp (see my web). Send me an e-mail, if you are interested in it. Rgds, Pavel |
#15 |
Pete,
what was the buffer package you have used? DIP8, TO220-5 or another. Thanks, Pavel |
#16 |
It was To220 -5 and i only got a couple as samples...now theve ran out
#17 |
Guys Ive found the fault...or at least i think so.
It would appear that i forgot to break the track underneath the board , on pin 5 of the op amp. Due to the orientation of components and links, it connected pin5 op amp to pin 3 buffer ..ouch.. Take a look at the image, it may explain a little more, this is only prototype board. Finnished will look a whole lot neater and bare legs will be sleeved. Just a thought , could i use slightly smaller rated regs , ie, 500Ma as apposed to 1A as seen before the smoothing caps. Anyone got a spare Buf634T out there in diy land, cant get anymore for another 14weeks !! |
#18 |
Pin 5 of OPA627 is connected very close to +Vs (in the inner structure), pin 3 of BUF634T is -Vs .... the faults are usually like this.
| Diamond Buffer - Super Buffer | peranders | Solid State | 34 | 16th May 2010 02:46 PM |
| Pre amp fault | Addolff | Parts | 4 | 6th January 2008 02:55 PM |
| Quad 306 fault | steevo | Solid State | 1 | 19th May 2007 06:27 PM |
| What to do? DVD laser fault. | richie00boy | Digital Source | 1 | 26th January 2006 02:33 PM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 07:50 AM |
| Page generated in 0.08629 seconds (83.00% PHP - 17.00% MySQL) with 11 queries |
