Old 5th September 2004, 01:18 PM   #1
Default Transistor/opamp circuit
With this circuit, http://www.mif.pg.gda.pl/homepages/t...s/simp200W.gif
which of these transistors would be best, if any?
http://www.centralsemi.com/Selection...TO_220Case.pdf
I plan to use this with an 3875. Does anybody know about how much RMS and peak power can be delivered to an 8ohm speaker?
Old 5th September 2004, 01:47 PM   #2
Default Re: Transistor/opamp circuit
IMHO using any power amp chip as a stage for a transistor based output is not too smart. Except if you already have the parts.
It's much better to use a good wide-bandwidth chip on first stage and go from there.
Carlos
Old 5th September 2004, 02:10 PM   #3
so this schematic is not a good idea?
Old 5th September 2004, 02:20 PM   #4
Well, I do have mj15003 and MJ15004 transistors, but they are TO-3 and are hard to mount on a heatsink. I coul get samples of the chips in that pdf file also, and they are to-220
forogt to mention, this is a subamp, so power is more important than clarity and sound quality (except I do want a good sounding amp for bass)
Old 5th September 2004, 02:36 PM   #5
johnnyx is offline johnnyx  United Kingdom
This circuit is being discussed in the "complementary output transistors in chip amp" thread.
This thread
Old 6th September 2004, 05:30 AM   #6
djk is offline djk
djk's Avatar
The 3875 with the 15003/04 running off a single 75V supply (±37) can do 400W into 4 ohms for a sub amp.
Old 6th September 2004, 05:16 PM   #7
400 peak? or 400RMS?
Either way, wow... i think i found my amp...
Plus my supply is close to that, +-/34 so I might even be close to that amount of power!
Since it would be getting so much power out of that circuit, would any of the components need to be more powerful? especially the diodes?
Old 6th September 2004, 08:32 PM   #8
I think there might be something wrong with those figures, as you can't get 400w in 4 ohms with just +/-37v on your supply. Only in bridged mode.
Where did you get those numbers?
Carlos
Old 7th September 2004, 12:54 AM   #9
That circuit is bridged, 2 boosted 3875 in bridge
Old 8th September 2004, 02:11 AM   #10
Has anybody used this amp and would recomend me use the 3875 and mj15003/4 for my subamp? Are those transistors good for this? I have them sitting around.
Also, any comments on this design just using the 2030?
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 01:52 PM
OPAMP with Transistor Output polsol Chip Amps 11 20th February 2007 10:16 PM
Opamp with transistor output linearity vossie Pass Labs 3 10th November 2004 08:40 AM
ALL TRANSISTOR OpAmp Samuel Jayaraj Solid State 15 10th August 2004 03:23 PM
Page generated in 0.11385 seconds (77.62% PHP - 22.38% MySQL) with 10 queries
