Old 7th September 2004, 05:24 PM   #41
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Don't forget, the pot is in parallel with the 22k resistor (from +IN to Ground).
I was assuming that it was isolated by the input cap.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 7th September 2004, 07:03 PM   #42
Banned
If you use the input cap, yes.
Not everybody uses it.
The input cap will only protect from DC from the source.
With NI, I would rather use the Ci cap. and have 2~5mv DC-offset.
Old 7th September 2004, 08:23 PM   #43
Nuuk's Avatar
But I guess you would rather go with inverted anyway!
Old 7th September 2004, 10:52 PM   #44
Banned
Yes.
Old 8th September 2004, 07:06 AM   #45
Cappy is offline Cappy  United States
Regarding the Ci cap that Carlos mentions, has anyone tried it on their Gainclone?
I might be interested in trying this with Brian's PCB. Carlos, should I stick with the 22 uF cap in that case?
Thanks.
Old 8th September 2004, 09:35 AM   #46
Banned
22uf is fine if you use 1k for Ri.
If 680 ohms, go for 33uf.
Bypass with 0.1~0.22uf poly.
Yes, I tried with and without that cap.
With the cap I have 4mv on one channel, 5mv on the other one.
Without the cap, I don't remember, it was long ago...
But it was much higher than this.
I used 33uf + 0.15uf poly.
Old 8th September 2004, 09:56 AM   #47
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
I've just read on the gc glossary that to bypass is to offer a low impedance route for high frequency noise. I just want to make sure this means connecting the 0.1uf in parallel with the 33uf?
I'll give the Ci cap a go too
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 8th September 2004, 10:41 AM   #48
Banned
Why use low ESR caps, then?
Puzzled by listening tests loninappleton Full Range 12 7th May 2008 10:20 AM
Listening tests of TDA1541A vs S1 vs S2 pop11 Digital Source 15 13th May 2004 06:46 PM
Listening tests Rob M Everything Else 37 4th February 2003 04:37 PM
Page generated in 0.08932 seconds (79.32% PHP - 20.68% MySQL) with 11 queries
