| Chip Amps Amplifiers based on integrated circuits |
#31 | |
diyAudio Moderator Emeritus
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#32 | |
When you choose lower values of input resistance (less than 22k), the offset value will go lower as well. On some chips it crosses 0 V reading and goes into positive (or negative ) offset voltage figure.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#33 | |
UrSv Those who say it can't be done should not stop those who are doing it. |
#34 | |
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#35 | |
Peter, are you saying that its ok to leave the caddock 22k on the board and add another smaller resistor (perhaps 1k5r) between signal in and signal ground?
#36 | |
Banned
In NI, with the "standard" schematic, these chips produce more DC-offset. It really depends on the input impedance (including the pot). Don't forget, the pot is in parallel with the 22k resistor (from +IN to Ground). DC will even change with the pot position. An op-amp as an input buffer would avoid this and you could tune input impedance for lower DC. And, an unpredictable issue, there are no two equal chips. With higher values for Rf and Ri you could use higher values of input impedance. To avoid high values of DC-offset, sometimes very different from channel to channel, you need to use the Ci caps (Look at Fig. 1 on the LM3875 datasheet). Good electrolythics bypassed with quality poly 0.1uf caps will bring DC-offset to a couple of mv, without affecting the sound. |
#37 | |
I would actually recommend leaving 22k Caddock (on the board) when adding smaller resistor. It should influence the sonics in more positive way. I noticed that having Caddock in shunt position somehow increases the impression of 3-dimentionality, much better than Vishay, for instance.
#38 | |
#39 |
Banned
With cheap pots you have to buy a bunch of them.
Log or linear, the problem is the same. Measure them all, and select the one(s) that have lower impedance mismatch between the two tracks(channels). Then... it's not cheap.
#40 |
If the cost of a worthwhile switch alone wasn't about 150%-200% of a Potentiometer, I'm sure more people would be making Attenuators.
Personally with my first GC I will probably use a Pot, and then when I get better at understanding and building amps I will give it to a friend and build another one with a buffer, attenuator etc. By that time I'd hope to have a dedicated pre and DAC anyways. Someone could make ALOT of money if they started making switches at the quality of say Elma but at half the cost. |
| Puzzled by listening tests | loninappleton | Full Range | 12 | 7th May 2008 10:20 AM |
| Listening tests of TDA1541A vs S1 vs S2 | pop11 | Digital Source | 15 | 13th May 2004 06:46 PM |
| Listening tests | Rob M | Everything Else | 37 | 4th February 2003 04:37 PM |
| Page generated in 0.10659 seconds (83.92% PHP - 16.08% MySQL) with 11 queries |
