| Chip Amps Amplifiers based on integrated circuits |
I built a set of LM3875 monoblocks using Brian's PC boards and Peter's chassis.
I am using the monoblocks as bass amps for my Oris Horn bi-amped setup. I've got pots on the gainclones to pad down the low-passed signal coming from the main 45 tube amps. My question -- instead of padding down the signal using the resistors in the pots, I wonder if it makes sense to lower the gain of the amps themselves? Optimally I would like to lower the gain somewhat and then use the pot to make final adjustments. This way there will be less resistance in the signal and I would expect more transparency. What do you'all think of this plan, lowering the gain from the standard 33db to 20 to 24 or so? Is there any downside? I see Peter mentioned in a post back in April 30-33 might be optimal, but I am weighing that against the (slight) loss in signal quality from more resistance in the signal. |
#2 | |
I did not do any comparison with regards to gain in NI amp. I just used what is in datasheet (and what seemingly 47Labs are using). It sounds well, so I didn't see a reason to research it further. I also need that gain as the amp is mostly used without line stage.
Now, I did some comparisons with inverting amp, by changing feedback resistor value, and it was definitely affecting the sonics. While 10k input resistance didn't change, I was substituting 220k, 250k and 300k for feedback. To me, it seemed like 250k in feedback sounded the best. I wouldn't expect anybody giving you a definite answer. Best approach would be to change the gain and compare it to a your current setup: what sounds better to you? ![]() Here a quote I noticed previously regarding the importance of proper gain setting: Quote:
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Peter, thanks....
I'll try lowering the gain and report back. By the way, the amps sound superb. |
#4 |
I don't think you'd get any sonic dif. especially if you use it for a bass amp. 20dB gain should be fine. Stability would be the only issue, so gain of 10 is fine.
/Greg |
#5 |
For bass amps it would be preferable to have lower gain (10x). Then you'll have more feedback and more control of the woofers. That's objectively; subjectively you might like it the other way around
Mads K |
#6 |
Imho there are two downsides of lowering the gain:
- you apply more feedback and therefore you loose some transparency. - as the open loop frequency vs gain is not linear, the more feedback the more linear up to RF, what is a disadvantage for audio purposes and eventually some LPF is needed. Very low gain is interesting for subwoofers, like mentioned above. Franz |
| Lowering Gain on an Aikido Preamp | SRMcGee | Tubes / Valves | 12 | 11th March 2007 09:49 PM |
| Vertical Bi Amping X250.5's Any Downside? | Tympani | Pass Labs | 7 | 5th March 2006 03:50 AM |
| lowering gain on Aleph 3 | hancock | Pass Labs | 4 | 21st December 2005 06:11 PM |
| Lowering gain of power amplifier, good idea? | squadra | Solid State | 10 | 5th May 2004 04:43 PM |
| Lowering gain in 12AX7 SRPP preamp | net-david | Tubes / Valves | 26 | 23rd December 2003 06:55 PM |
| Page generated in 0.10932 seconds (78.69% PHP - 21.31% MySQL) with 10 queries |
