| Chip Amps Amplifiers based on integrated circuits |
#21 | |||
Patrick |
#22 |
From what ive read, it seems that having an input resistor is "safer" for your amp/source/speakers. But its not really necessary if you dont have any major dc offset problems without it. Peter i believe suggests to not use it if possible because he designed a minimalist GC, so one less component in the signal path could only help (if there arent other consequences of course).
if you are using a pot, then there is some resistance in the signal path anyway (except at max volume of course) so you should not need the input resistor. If you are building a true amp (no volume control) than an input resistor is probably necessary. any corrections welcome from the more experienced What i would like to know is what causes DC offset to increase or decrease when you change volume. How is DC offset related to input resistance? maybe with answers to those questions, i will be able to decide what value of linear pot to use in the fake lawing setup. And if the input resistor is still necessary in that case. |
#23 |
Would putting a greater value resistor is R2 decrease dc offset, if one cannot find what is causeing the problem, which is of course better?
Thanks, Josh |
| So I did try all those different potentiometers | Peter Daniel | Chip Amps | 308 | 12th August 2009 02:29 PM |
| potentiometers | zahlm | Parts | 1 | 15th April 2004 05:43 AM |
| Potentiometers | slogan2112 | Solid State | 2 | 19th December 2003 06:54 AM |
| Page generated in 0.07721 seconds (71.82% PHP - 28.18% MySQL) with 11 queries |
