| Chip Amps Amplifiers based on integrated circuits |
After getting my input jacks isolated from the chassis, and verified by checking the resistance with a DMM (OL, which is greater than 10MOhm) I put the amp together in the chassis and got an odd problem... No matter what I do, I get -vin on the output. I have checked to make sure there are no wires crossed, and I dind't see any. I reheated the solder joints to make sure they are good. Resistance from +in to -in is ~21K, which I would expect, rail voltages and ground seem to be correct.
I have looked at the circuit a few too many times at this point, which is why I'm taking a break and posting to see if anyone has made this mistake before. Chip is an LM3886, built to National's circuit. Any thoughts where to look since my eyes are fried? |
#2 |
-Vin? Do you have balanced input?
Mads K |
#3 |
does any one have a balanced version of the gain clone schematic ? id like to build a pair for a pair of studio ./ computer speakers : O )
Baby Danika, Born January 20th 1:54am.. http://itsparks.dyndns.orgMix a LittleUntangle&Opendns.org Perfect.. |
#4 |
triple check your wiring, ive had this problem several times when ive connected the wrong pins up..
#5 |
Electrons are yellow and more is better!
Adam, do you have any resistor from the MUTE pin? If not, add 10-33 kohms.
/Per-Anders (my first name) or P-A as my friends call me |
#6 |
Probably an obvious question but have you isolated your speaker terminals?
Check that you have the correct voltages at the pins of the chip.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#7 |
This -V on the output, against what is that measured? What exactly is '-vin'? Neg supply?
Also, if you isolated the input, is there a ground connection from the input to supply/speaker ground and amp ground? Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#8 |
Banned
The LM3886 has a ground pin to connect to power ground.
Did you? |
#9 |
After taking the whole amp apart, I found the problem. I forgot to put a resistor from input to ground, and all is good now. I get the same effect if I just plug something into the input, but I was testing in steps.
For those who asked above, I was talking about the negative rail voltage showing up on the output. As a theory question, why did not having a resistor from input to ground drive the output to -35Vdc? Thanks. |
#10 |
When you put the -in to gnd resistor you are refering the input to gnd. When a signal is applied to the +input it comes out amplified at the output, and a small (determined by the ratio of this and the feedbackresistor) portion of the outputsignal is fed back to the -input and hereby reducing distortion and setting the gain of the amp.
Mads K |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 06:10 PM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 11:18 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 07:15 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 06:17 AM |
| I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output | iklari14 | Digital Source | 30 | 18th July 2003 01:57 PM |
| Page generated in 0.09827 seconds (78.21% PHP - 21.79% MySQL) with 10 queries |
