| Chip Amps Amplifiers based on integrated circuits |
hey guys, i ll receive tomorrow my lm4780 and lm3886 chips, ill goto buy 2 power suply today, an normal and try to find an toroidal ... too.
im looking into both datasheets and i see that the power that i need will be <= 80v. the question that i want to ask is... is ok an power supply with the primary 220v and secundary +80v? is ok too primary 220v and secundary -40 and +40 ? sorry for the dumb question ![]() thanks.. |
#2 |
I would go for one of about 200 to 300VA with 25-0-25 rails, but if you do a little work and have a look thorough some of the other threads then you will find more than enough info on the best choice for your application.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
well i found some post that say that -25/0/+25 is the best choise....
what abt the amps? how many ampers? and latest question... if i ll use bridged chips, is ok to use the same power supply? |
#4 |
Banned
To open this thread you had to select the option "Have you searched? ".
You lied.
#5 |
no dude, i searched, but i dont understand 100% the posts... ppl say diferent things and the posts talk more than just the simple question....
i searched abt ampers without lucky
#6 |
6 - 8 A should be fine. You can go even less if cost an issue.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#7 |
people are suggesting a 300VA xformer... that means:
25V + 25V = 50V 300VA/50V = 6A or, you can go the other way. 25V + 25V = 50V 50V * 6A = 300VA. there you go. now you can figure it out in the future. |
#8 |
thx guys...
#9 |
cant found toroidal power supply in my country
i can get an 25+25 normal power supplyit will be ok? it cost me like 50 U$S
#10 |
btw, when i asked for the power supply they told me that its an 300watts suply, is that ok?
| OPT Trafo | Dynsdale | Tubes / Valves | 10 | 22nd March 2009 07:41 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 01:30 AM |
| SE Trafo for PP use | dsavitsk | Tubes / Valves | 15 | 8th August 2007 09:27 PM |
| Of what value is this trafo? | wxn | Parts | 7 | 13th June 2005 01:08 PM |
| Trafo to buy for PWM amp | partyjups | Solid State | 6 | 19th December 2001 11:32 PM |
| Page generated in 0.11130 seconds (77.85% PHP - 22.15% MySQL) with 10 queries |
