Old 30th August 2004, 06:24 PM   #11
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
$50 isnt bad. and yes, it will work.
a 300 watt supply is roughly a 300va supply. for a gainclone, you should be fine.
Old 30th August 2004, 06:26 PM   #12
ok ill buy the normal trafo, btw... ill get too much diference using that isntead an toroidal?
Old 31st August 2004, 01:34 PM   #13
thanks again dudes... i need an power supply that support 6A on each rail? or just support 6A on both?
understand me?
Old 31st August 2004, 01:37 PM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
on both. it doesn't have to be toroid, regular trafo is OK too.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 31st August 2004, 01:52 PM   #15
thanks peter....
one last question (before burn my speakers)
i have an schematic that use some strange CAP, MKS4CAP and elko5, i cant find that stuff in my country, what other caps can i use??
the schematic say
elko5 68uF 16V
and
MKS4CAP 1uF
btw
300watts power supply = 50v*6Amps => its the power that i need, right?
ill buy the power in just 1 hour.....
(they need 1 week to send me the power supply) is not an standar value..
Old 31st August 2004, 02:00 PM   #16
Just use any caps that you have (similar value though).
>300watts power supply = 50v*6Amps => its the power that i need, right? <
Yes.
www.audiosector.com
Old 31st August 2004, 02:17 PM   #17
thanks...
OPT Trafo Dynsdale Tubes / Valves 10 22nd March 2009 06:41 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
SE Trafo for PP use dsavitsk Tubes / Valves 15 8th August 2007 08:27 PM
Of what value is this trafo? wxn Parts 7 13th June 2005 12:08 PM
Trafo to buy for PWM amp partyjups Solid State 6 19th December 2001 10:32 PM
Page generated in 0.10939 seconds (60.83% PHP - 39.17% MySQL) with 10 queries
