| Chip Amps Amplifiers based on integrated circuits |
#11 |
I would think that using capacitor would definitely be more safe approach, but again, I'm not even using Zobel, so coupling caps are at the end of my list
Resistors have less sonic effect than caps, and are cheaper too.We were using coupling caps in the beginning, but later decided it was not neccessary. Having said that, while I was experimenting with ML preamp, I had some instances when suddenly 24V DC appeared at the speakers. Fortunately, I was quick enough to disconnect the amp's outputs.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
| Role of 10K Resistor on input? | gychang | Class D | 7 | 11th July 2009 07:57 AM |
| Bypass input resistor and use a 20k pot instead? | newbie23 | Class D | 5 | 13th June 2007 09:04 PM |
| plate resistor, input lead | vlljpior | Tubes / Valves | 7 | 23rd January 2005 11:06 AM |
| NIGC input resistor | tonitze | Chip Amps | 1 | 14th May 2004 05:50 PM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.06403 seconds (70.03% PHP - 29.97% MySQL) with 10 queries |
