How to determine optimal bias class A current?
Old 30th August 2004, 06:21 AM   #1
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Default How to determine optimal bias class A current?
I've been using resisitor to connect opamp's output stage to -V to achieve Class A operations. Yet, I have the following questions: -
1. How to determine the optimal bias current for different opamps?
2. What will happen if the current is too high?
3. What will happen if the current is too low?
Sunny
Old 30th August 2004, 08:22 AM   #2
arthur is offline arthur
too high bias will generate heat ,or the chip die
too low bias=no use
Old 30th August 2004, 09:49 AM   #3
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
The best way to determine it is to look at the expected output current. You want a class A current just above the max expected peak output current, so that the output stage will not cut-off.
Example: Suppose your max output level is 5VRMS which is about 7V peak. Your load impedance is 1K. That means the max output current will be about 7mA. So you should bias the amp in class A say 8mA. With a supply of 15VDC that will need a resistor of just below 500 Ohms.
The dissipation of your opamp now becomes 8mA from the POS supply, say of +15VDC is about 60mW (plus the 'normal' quiescent dissipation, of course, see the data sheet), which should pose no dissipation problems.
Your values may be different, but that's the principle.
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
How to determine optimal bias class A current?Hide this!Advertise here!
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 9 19th August 2012 06:29 PM
class a bias current and distortion jerluwoo Solid State 1 2nd May 2007 07:48 PM
Rule of thumb for BIAS current in class A azira Pass Labs 4 31st January 2007 12:12 AM
How to determine heatsink/bias Raj1 Pass Labs 8 4th January 2003 07:19 AM
Copyright ©1999-2017 diyAudio
