| Chip Amps Amplifiers based on integrated circuits |
Hi
Basically im a student in England and wish to make a small PA system, i have a basic design but i'm searching for ideas on circuit boards for the amps. They are the speakers i have chosenSpeakers they are cheap and full range and i'm hopining therefore they will be suitable without the need for separate tweeters and subs. So i have the speakers sorted and the wooden cabinets although im using transparent acrylic for the front of the cabinets. So all is left is the amp i would ideally like something of 40watts per channel, stereo of course and i have been looking and found a few designs on the net which i can use to create the PCB then buy the components but they aren't really set in concrete that they work well as they are free designs and often poorly supported by poor diagrams etc.... I was wondering if any of you could help me out if you know of any websites are anything providing good circuit diagrams of anything of say 30-45watts per channel stereo amps. I intend to just have two inputs with separate level volume controls.... it is just a basic amplifier and speaker package in essence. Thanks for any help you can offer, most appreciated.. Dave |
#2 |
Well u can try reading Gainclone threads here in this forum, coz they are easier to build and are cheaper, moreover they can pump out enough power to match ur speakers, other wise u can try STK4191 series, or if u dont know anything try putting ur hand on a ready made kit.
Cheers |
#3 |
Dave, this will be a small PA with those drivers and jsut 40 watts but I guess you realise that already.
If you are happy with just 40 watts then as Adibr says, a Gainclone will do adequately. The advantage of the GC is that there is so much help but if you really can't find what you are looking for, contact me through the form on my wb site and I will try andhelp you if I can.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
hmm i thought i replied to this...sorry guys
right ok i have taken a look at your website....i'm going to run through it all again...basically its gone a little over the top of my head, i mean its not ultra powerful, but a 40 watts or there abouts per channel (stereo) is what i'm looking for, the other major problem is powering them, i'd rather use a conventional power supply i know you can get some to rang up to 24V DC current.. |
#5 |
I'm not sure if you are referring to GC's on Decibel Dungeon, but apart from the one with the regulated supply, the others all have a 'conventional' power supply.
If you want 40 watts per channels, simply follow the design of my GC monoblocks.
#6 |
ok thanks
http://www.decdun.fsnet.co.uk/ is it on that site so yep a basic 40 watt per channel stereo amp to drive 2 8 ohm 45watt full range speakers.. could you direct me to where the info is please? Thanks again |
#7 | |
#8 |
sorry, is this gainclone monoblock 40 amp a particular design?
If i go to your site there area lot of other pages referring to amps but i cannot seem to find anything about monoblock 40 watt per channel stereo amp? I was wondering if you had a direct link to that particular amp? Thanks again |
#9 |
There is only one monblock design there. The reason that there is no reference to power output is that it is dependent on the power supply, more specifically the transformer rating.
Once you have built an amp, it can operate with a range of PSU's so the power output isn't set in stone. See here .
#10 |
Yes, I agree to go with the 3875, but as this is a PA amp, HiFi is not at all required, so I would say just use the simple schematic on National's datasheet.
With a single PA driver, you will most likely never notice the diference of the extra parts nor the higher quality parts. But if you have the money and feel like building the best you can, then definately go with the schematic on Nuuk's site |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 06:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 11:27 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 11:39 AM |
| Why do some Bogan amps sound so good as guitar amps? | amperex | Instruments and Amps | 7 | 22nd June 2006 12:46 PM |
| Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? | percy | Chip Amps | 31 | 13th January 2006 02:33 AM |
| Page generated in 0.11438 seconds (82.59% PHP - 17.41% MySQL) with 10 queries |
