Old 3rd September 2004, 09:14 PM   #11
Default Rectifier
Do you guys think the rectifier is damaged?
How would I test this without dissassembling the amp?
Harry
Old 3rd September 2004, 09:44 PM   #12
I think I found the problem. I was testing the rectifiers
and the measurements did not make sense.
Then I dissassmbled it and I looked at some other
bridges I had in a bag. It turned out the polarity
on my bridge is mislabeled!!!
This took me almost a whole day to figure out.
I will let you guys know if this has solved the issue.
Old 3rd September 2004, 10:20 PM   #13
Twice look than once cut .
Old 3rd September 2004, 10:49 PM   #14
Default Looked many times
I checked the polarity many times (Visually).
I actually never measured the bridge. Both
bridges that I put in are labeled wrong. The
company must have printed their information
on the wrong side or something like that.
How many of you measure the polarity of
a bridge before you assemble the amps?
I know I will next time.
Harry
Old 4th September 2004, 02:09 AM   #15
Default Solved
That was it. The fuse does not blow anymore.
Also 2 power supplies including rectifiers can
be hooked up to one transformer. I still did not
try it with sound though. One step forward.
Harry
New 'lytics blow the fuse glorocks Parts 13 4th June 2009 02:54 AM
New ST-70 blowing 3 amp slow blow fuse Jimthemeek Tubes / Valves 22 3rd May 2009 10:56 PM
Sa-5.1 blow fuse jpweaner2 Tubes / Valves 0 3rd May 2007 01:36 PM
Soundstream SA 245 - Blow Fuse babygot Car Audio 4 7th January 2005 05:06 PM
Tube amp fuse blow out Gabevee Tubes / Valves 1 4th March 2002 03:55 PM
Page generated in 0.06480 seconds (81.78% PHP - 18.22% MySQL) with 11 queries
