| Chip Amps Amplifiers based on integrated circuits |
hey guys, i was looking into the datasheet of lm4780 and lm3886
and i found that the THD in LM4780 is 0.5% and 0.1% into LM3886. i think that these numbers ar not good enought for an HIFI amp, right? and another question.. if i use 2 ICs to create an bridged amp, ill get more THD? or will be the same as if i use only 1? hope ppl understad me |
#2 |
some amps with .01% can sound really bad
other amps with 2.0% can sound really good chip amps if done well can sound pretty good If you bridge you will have twice the voltage available, so it's good for low voltage supplies and /or Higher impedance loads. If you speaker are 4 - 6ohms bridging will not be ideal. each chip will see 2 - 3 ohms and chips mostly have limited current levels Why not start with a single chip and see if you like the sound before you try bridging - the sound charactor does not change that much with bridging hope this helps |
#3 |
ok, so u think that this kind of CHIPs are better than create an AMP using Transistors?
i was looking into my yamaha receiver today and it use 2SC4468 and 2sc1695 Transistors for the amp. |
#4 |
read the datasheet... it seems that at 1Watt both chips perform very similar... THD , at 30W the LM3886 seems a bit better 0.003% v. 0.005 %, but my guess is that the LM3886 and LM4780 are very similar in design and performance...
#5 | |
with a chip most the difficult design work, layout and construction is done for you. The chip itself brings some advantages. There are a great place to start and extrememly good value john linsley hood simple class A is a great class A discrete design see JLH 10 Watt class A amplifier and http://www.tcaas.btinternet.co.uk/index-1.htm for a great AB design look here http://www.printedelectronics.com/pr...ts_aksa55.html that should keep you busy reading for a while...
#6 |
thanks mikelm
i ll test the 3886 and 4780 after i received it and compare the sound with my yamaha amp. |
| Paralleling LM4780/3886: any impact on sound quality? | Arnop | Chip Amps | 51 | 4th May 2011 02:37 AM |
| How many 3886 chips required to drive these woofers? | rhythmdiy | Chip Amps | 18 | 8th October 2007 05:07 PM |
| Parallel LM4780/3886: leave away those 0,2Ohm between the outputs? | Bassterror | Chip Amps | 13 | 11th August 2006 05:10 PM |
| Paralleling LM4780 chips? | Dominick22 | Chip Amps | 29 | 26th February 2006 11:23 PM |
| Bridging 2 LM4780 chips | akunec | Chip Amps | 9 | 17th April 2005 08:25 AM |
| Page generated in 0.09180 seconds (74.15% PHP - 25.85% MySQL) with 10 queries |
