| Chip Amps Amplifiers based on integrated circuits |
#11 | |
Yeah thats exactly the same thing as me, ive never had a problem with my LM1875's but these 3875s..... |
#12 |
The noise has (until now) only occured in test set-ups. No shielding, proper grounding etc..
I hanven't finished your immaculate chassis yet, Peter. Marc |
#13 |
This happened to all of my 8 channels Brian GC, ( 2 amplifiers) This is only of course with input after power off. when I later added large caps at the rectifier I got as much as 18 20 seconds for the second "play" of a second or 2. I fixed this with a bleeder resistor across the rails. There seems to be 2 voltage levels that the 3875 will perform, standard full and a much lower one.
This was with 1500 pana caps at the chips. Now using only 47ufd at the chips but 10,000 ufd at the rectifier and regulate with 338s there is no second "play"
Sheldon D |
#14 |
well ive been poking my multimeter around in places, and found some interesting but seemingly pointless results
On an amp that doesnt second off... The +ve rail discharges much slower than the -ve and seems to sit around 5.1v The -ve rail discharges faster, and seems to sit at around 3.5v The same is true of an amp that does second off, however, when the negative rail is around 3.5v and the positive rail is around 5.5v it second offs, leaving the pos rail at 4v and the neg rail a 0v. Right now im not sure what to make of this?? although it would seem to hint that its a difference in the 3875's rather than the power supplied to themNik |
#15 |
Beggar,
do you use additional caps? I remember having had similar problems using two additional caps (well, one has to try) with 10.000uF each. Best regards, Oliver |
#16 |
Electrons are yellow and more is better!
The best you can do is to track the supply voltages when you are turning off power. From this you can see something. Can you borrow a digital oscilloscope?
Here is a picture of my amp when turned on and off. Positive voltage, signal out and negative voltage Power on Power off
/Per-Anders (my first name) or P-A as my friends call me |
#17 |
All what you describe here is normal behaviour of typical amp which have not allsymetrical connection and you can't do nothing with this. All amps which have not output relay can cause problems by switch on or by switch off. If this amp have not problems with DC voltage on output by switching off, so let it be, 'cos I say again, it is normal process. Clear solution is ( if you can't let it be ) output relay, which immediately switch off output by switch off mains - but it will be quite different amp
#18 | |
As I mentioned before, this is not a normal behaviour with those chips. The relay shouldn't be required (to mute those transients).
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#19 |
Yes, Per have thruth - help shorting of input by switch off
#20 |
Just my guess of what might have caused the "come back to life after power down" problem. I don't know the circuit layout of your amps, so here is a question for you: Do you have a resistor in series with the input pin? If you look at the suggested application on the first page of the data sheet for LM3875, this resistor is called "RB" and has a value of 1kohm. On page 6 of the data sheet is an explanation of why RB is needed : "Prevents currents from entering the amplifier's non-inverting input which may be passed through to the load upon power-down of the system. … This phenomenon occurs when the supply voltages are below 1.5V." This sounds like the phenomenon you are experiencing with your amps. Ciao, Kurt Chang |
| Should I bother bringing these back to life? | lowpoke | Multi-Way | 4 | 15th March 2009 01:37 PM |
| Gas discharge tubes in transient overvoltage suppression | earl of sodbury | Everything Else | 2 | 15th April 2008 10:44 AM |
| DC offset on turnoff | dm2a | Solid State | 6 | 13th September 2007 09:38 PM |
| DC offset... On turnoff? | JoeBob | Chip Amps | 2 | 7th August 2003 06:23 PM |
| Page generated in 0.12133 seconds (81.63% PHP - 18.37% MySQL) with 10 queries |
