Old 9th September 2004, 10:59 PM   #41
moamps is offline moamps  Croatia
Originally posted by johnnyx
Does the soft start slow it down all the time, or just at start up?
Just at start up.
Old 10th September 2004, 01:30 PM   #42
d3imlay is offline d3imlay  United States
I think it might be a good idea to review the requirements of a voltage regualtor. Most of the regulators I've seen by diy's look only at the output voltage with normal input voltage. However, it's important to consider the worst case current, and input voltage.
A standard practice for worst case input voltage is +/_ 10 percent of nominal. Assuming nominal to be 120 volts then the power supply must regulate the output voltage between 108 and 132 VAC. Rarely is the low end taken into consideration. It appears that the LM338 input voltage needs to be 5 volts greater than the output voltage. Consequently the the raw DC voltage at Low Line (108) has to be 5 volts above the output. At the high end the Vin-Vout will be much higher and the regualtor must have enough heatsinking ability to keep the regulator from failing or shuting down. This is the biggest disadvantge of linear regulators. You end up with a lot heat to get rid of.
The regulator should be monitored with an oscilloscope while the input voltage is changed with a variac while providing full load current. I have seen many regulators become unstable and break into oscillations at low input voltages.
Old 13th October 2007, 04:17 AM   #43
Send a message via ICQ to erictoucan Send a message via AIM to erictoucan Send a message via MSN to erictoucan Send a message via Yahoo to erictoucan
Default Using a diodo across the input and output to protect the 338
I think because the capacitor at the output discharge to the input through the regulator and damage the regulator. So just connect a diode across output and input can serve the task without worrying about blow up the regulator.
I think it is hard to say what value of capacitor at the 3875 is safe. Using a diode is the way. You may refer to the application notes of national pdf file for details.
chung
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Can we handle more zen? bertjan Pass Labs 10 31st July 2006 10:04 AM
Speakers: 8 ohms vs. 16 ohms KT Multi-Way 2 14th April 2006 05:06 PM
Will 7915 Regulator Handle LHMAudio Power Supplies 14 28th March 2006 03:47 PM
Too hot to handle Panelhead Pass Labs 3 8th May 2003 12:10 AM
Page generated in 0.07695 seconds (68.76% PHP - 31.24% MySQL) with 10 queries
