| Chip Amps Amplifiers based on integrated circuits |
#21 | |
I must brush up on my Cantonese/Mandarin!
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#22 |
The speaker chapter now has some pics, so its more understandable.
Charles ![]() http://www.mother-of-tone.com/speaker.htm |
#23 | |
Thanks Charles!
#24 |
Hi Charles;
<my apologies for straying OT from chipamps to one and all> Thanks for posting that link. It's a very interesting read on driver design, particularly the section on internal resonance sources in construction. I'd never thought about the physical difference between a ferrite mag and an alnico one in this way, but given the sonic effects of a little felt pad on the back of a ferrite magnet, I do believe you're onto something (maybe the felt pad helps dampen ringing in the ferrite mag that's being pumped by the resonance mode of the internal cavity.....). Perhaps the most important single observation though, is that most modern drivers are not designed by ear, but are designed by specifications that don't really correspond well with how things sound. That comports well with my own beliefs and it alone goes far to explain why I've had so much success with moderate powered amps of simple construction mated to moderate cost speakers of "traditional" design (i.e. paper VC formers and cones). Eliminating the design compromises necessary for high wattage amplification also eliminates the sonic compromises they necessitate. And, as I pointed out in a thread in a different board, it seems that designers these days are putting too much emphasis on things we can't hear (treble into the ultrasonic when most of us "over '40's" can't hear a 15kcps flyback trannie in their TV sets anymore) while ignoring things we can hear (like proper midrange). All the best, Morse |
#25 |
have you looked at a tda2003, i know its good for a supply and gives 5>7 watts. i built 4 for a caravan sound system and they work great. not true G. C. but worth a look. hope it helps, c ya, steve.. ..
you all laugh because im different, i laugh because youre all the same.. .. |
#26 |
Who makes the "cheap Chinese" speakers?
#27 | |
#28 |
For 12 V I would suggest TDA1560Q.
UrSv Those who say it can't be done should not stop those who are doing it. |
#29 |
From the BYOB site :
" The BYOB amp sports 2 x 10 W into 8 Ohm respectively 2 x 20 W into 4 Ohm and even more into 2 Ohm. This high power-level is achieved through bridged operation. That means, both channels are internally bridged by design. " ...and power supply voltage is 12V.... Are we talking about some of the TDA stereo bridged car amp chips ? Regards; Matjaz |
| Suitable woof & tweet for CV Full Range chip amp? | lunchmoney | Chip Amps | 3 | 20th March 2011 07:00 PM |
| how to build a 12 volt dc power supply? | michelevit | Class D | 5 | 22nd December 2006 08:53 AM |
| How to use a 220 Volt power supply at 12 Volts in the car? | Mr. Old School | Car Audio | 3 | 10th March 2006 01:11 AM |
| Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? | Layberinthius | Tubes / Valves | 0 | 11th March 2004 09:49 PM |
| Page generated in 0.11361 seconds (75.29% PHP - 24.71% MySQL) with 11 queries |
