Old 22nd August 2004, 06:08 PM   #1
Default Transformer question?????
I really did search but the results were inconclusive...
I have a couple of cheap frame transofrmers from PE. These one's here...12 volt center tap
When they say 12-0-12, does that mean I get 24V out? If I have two of them, how would they be wired to produce 24V. In series?
Do I follow up with the BrianGT diaghram for CT transformer rectifier board construction then? Right?really
Old 22nd August 2004, 06:24 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Depends. If you put the centre tap to gnd and use two diodes from the 12V AC pins to get DC, you get 12V * sqrt of 2 is about 17VDC minus some losses. If you use the two 12VAC pins disregarding the center tap, with a bridge rectifier, you get 24V * sqrt of 2 is about (you guessed it) 34VDC minus some losses. But, in both cases, the transformer can only deliver its rated load.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Transformer question? mcameron Parts 5 23rd January 2005 07:52 PM
transformer question xcortes Chip Amps 0 31st October 2004 05:04 AM
Transformer Question TunaFish Tubes / Valves 15 18th June 2004 11:20 PM
Transformer Question toque_101 Chip Amps 2 26th January 2004 05:21 AM
Page generated in 0.06316 seconds (69.99% PHP - 30.01% MySQL) with 10 queries
