| Chip Amps Amplifiers based on integrated circuits |
Does anyone have a single sided PCB design pictures for LM4780? I wanted to try out this amp but as a starting point i would like to experiment with a single sided PCB instead of two sided. Thanks in advance. |
#2 |
With one sided PCB you can't to get with this circuit optimal configuration - forget on it.
#3 |
I know there was one, but I can't remember where. Try a google search.
#4 |
thanks Upupa, so two sided is better is it? What about the pcb design given on national's website/datasheet. Is it good enough?
If thats better then I will build a two sided one. So far I havent tried my hands on two sided pcbs.Will have to give it a shot to see how it goes.. |
#5 | |
Carlos |
#6 | |
http://hepso.dna.fi/misc/lm4780/lm4780-pcb.pdf Carlos |
#7 |
yep, thats it.
Thanks |
#8 |
To rs1026 : PCB on datasheet is " electricaly " optimal, but not nice
- " optimal and nice " is my version . How you will see, design of both sided PCB is much more easy than one sided.To carlmart : This showed PCB is typical example of " nonoptimal " solution : too long thin traces with too high current density on rails and output. Problems with resoldering of LM. |
#9 |
#10 |
With 3886 is it easy, 'cos distance of pins is great, but question was about 4780
| Single sided PCB for Zen v4 | kirc | Pass Labs | 59 | 3rd May 2012 11:29 AM |
| A good single sided PCB for bridged LM4780? | Ulew | Chip Amps | 54 | 25th October 2008 12:46 PM |
| Lm4780 Single Sided Pwr Supply Pcb | dgaxeman | Chip Amps | 6 | 2nd May 2006 10:50 PM |
| Single Sided PCB for Zen V4 | GeorgeBoles | Pass Labs | 0 | 29th August 2004 12:55 AM |
| Page generated in 0.08423 seconds (83.89% PHP - 16.11% MySQL) with 10 queries |
