Old 19th August 2004, 12:44 PM   #1
MWP is offline MWP  Australia
Default Design critique
Hi all,
Ive just finished my new design for a DAC + Gainclone Amp i planning to build shortly.
Its one of the bigger more complex designs ive attempted from scratch.
Anyone care to give it a once over?
It would be nice to get some comments/thumbs-up from you guys before i put in the many hours designing and building the PCBs for it.
http://www.overclockers.com.au/~mwp/...p-dac-amp1.pdf
BTW...
Yes, i know there is no volume control besides the two step relay atten. Volume control will be before the DACs.
And, yes, one single ground plane instead of split.
Thanks!
Old 19th August 2004, 03:40 PM   #2
Default Re: Design critique
Originally posted by MWP
Hi all,
Why don't you feed the bridge directly from the PCM1798? You already have differential outputs for that.
If the reason is to buffer it or to amp it, then it might be better to use a differential in/differential out chip. As it is there might be some CMRR imbalances.
Carlos
Old 19th August 2004, 04:07 PM   #3
Default Re: Re: Design critique
Yes, but they are current outputs which require IV conversion.
Using the LM3886's to do this would create gain problems and would probably be unstable.
Old 19th August 2004, 04:33 PM   #4
johnnyx is offline johnnyx  United Kingdom
Usually the Zobel network goes directly to the amp output, rather than to the output sockets.
Old 19th August 2004, 04:39 PM   #5
Can you explain this further?
I dont understand.
Old 19th August 2004, 07:16 PM   #6
GregGC is offline GregGC  Canada
Hi all,
BTW...
Thanks!
Looks good to me. The only thing I find would be that the VCANCEL may have to be different for the Left and Right chanel (or even between the inv. and noninv. of the opamps within the same chanel). So the DC offset could suffer (in your case the IGC has a DC gain of 18), but if you put caps between GC and OPA's (the 10k to gnd from +in of 3886 may have to go to 180k or so)you'd be fine. Hope I didn't confuse you.
/Greg
Old 20th August 2004, 03:54 AM   #7
/Greg
Good point.
I prefer to keep DC blocking caps out of the audio line as its quite difficult to find good quality caps here.
I might give a separate DC bias adjust for each of the IV opamps.
Please critique my PCB design darkfenriz Class D 26 8th August 2008 03:49 PM
Critique my first design bigwill Tubes / Valves 11 3rd June 2007 11:30 AM
critique my amp design please AudioGeek Solid State 6 26th February 2007 04:50 PM
Please critique this design.... Christof Multi-Way 22 10th January 2004 07:17 AM
Critique my USB DAC design MWP Digital Source 14 14th August 2003 07:00 PM
Page generated in 0.11365 seconds (77.94% PHP - 22.06% MySQL) with 10 queries
