Old 19th August 2004, 06:22 AM   #1
Send a message via AIM to Richard.C Send a message via MSN to Richard.C Send a message via Yahoo to Richard.C
Smile Sound quality,which is best?
Hi all
I'm going to choose one chip amp of LM4766,LM3886,TDA7294 or TDA1514 for my personal Hi-Fi center,
which sounds best?
Thanks!
Old 19th August 2004, 10:33 AM   #2
why do no one answer me?
Old 19th August 2004, 11:36 AM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
There is probably no uniform answer to this question. It very much depends on the way these chips are implemented. I dought it that someone here would ever have compared them.
The one real answer is to try them all and listen.
/Hugo
Old 19th August 2004, 08:36 PM   #4
GregGC is offline GregGC  Canada
Default Re: Sound quality,which is best?
Originally posted by Richard.C
Hi all
which sounds best?
Thanks!
LM3875.
Old 19th August 2004, 10:43 PM   #5
demogorgon's Avatar
Send a message via MSN to demogorgon
based on what i hear, the LM 3886 would be a solid choise, and i hope i'm correct as im ordering them as i write this post..
Old 20th August 2004, 04:36 AM   #6
I can't understand that ....as to the parameter in the Datasheet ,LM3886 is better than LM3875 but the SNR,why many peple think LM3875 is the better choice?
Old 20th August 2004, 03:10 PM   #7
Some people prefer the sound of tubes and the parameters of those amps are nowhere near the ones of SS. I think it's just easier to work with LM3875 compared to lm3886, because it has less pins to work with and I like P2P. Sound: you have to decide for yourself. Configuration, schematic, parts, preamps, speakers..... To me, the less parts in the way of the signal the better (combined with a sensible circuit design, of course), because all components have their sonic characteristics, so less time spent on tweaking (less places one can screw-up the signal) and more time for listening to music.
Build them and tell us what you think.
/Greg
Old 20th August 2004, 03:44 PM   #8
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
if you stick with power opamps that are 'known' to be good, it's more a matter of choice...
Do you want to match them with your (theoretically speaking) hard-to-drive loudspeakers or do you have a fantastically easy to drive, super high sensitivity horn system?
here's a thread that lists the most used power opamps in commercial products.
Old 22nd August 2004, 05:16 AM   #9
It's also based on mute mode. If you need mute mode for your power amp, I suggest you use LM3886, LM4780 and TDA7294 for your amp. For me, LM3875 and OPA549! very good!
Old 23rd August 2004, 08:52 AM   #10
Default LM4766
I prefer to use lm4766 because it's easy to buy,and some people say it sounds like a tube amp, I'm interesting with it.
but I wonder ...as a newer type of NS 'overtrue' amp series, why fewer people have uesd it?
Best possible sound quality from +12 ATX PSU Arnop Chip Amps 3 6th April 2009 12:40 PM
CSS FR125S Sound Quality the full ranger Full Range 2 11th December 2007 09:45 PM
Better Sound Quality LqDFx Car Audio 14 16th June 2006 05:49 PM
Quality Control differences = variations in sound quality? KT Class D 0 14th November 2004 07:51 AM
TAD sound quality Kal Multi-Way 12 6th April 2004 07:16 PM
Page generated in 0.10592 seconds (78.60% PHP - 21.40% MySQL) with 10 queries
