| Chip Amps Amplifiers based on integrated circuits |
hey guys, can someone tellme an good IC to build an Car audio amp?
#2 |
My next experiment is going to be with this one
http://www.semiconductors.philips.co...2Q_ST_SD_2.pdf
Hmm .. no .. I really haven't got anythig cool to say .. |
#3 |
ok, ill see that, btw, how ppl found specific chips? i mean, exist some place where u can see all the chips sorted by for example audio amps?
#4 |
Google?
#5 |
well i know google, i just asking for an DB but is ok.....
btw, still giving ppl more Chips to use ![]() and maybe an cool schematic |
#6 |
does philips do samples? i wasn't able to find much on the subject
#7 |
no, they do not, I have emailed them with the same question a month or two ago.
Not many chips will get the power you want from a car. The reason is if the chip is made to run off of 12VDC, that limits the total output power to a few watts. Car amps use speical power supplies to turn the 12VDC into whatever they want (usually around +/-35VDC) How that chip works, I don't know. All I know is I'm like you, I wish they had samples. Just wondering, can that chip be bridged? edit: never mind, its already in BTL config. |
#8 |
hi AGGEMAM,
Me too is interested in building a Car Amp out of TDA1562. I had no prior experience in building a car amp. Had take a look at the Data Sheet. Does that means that based on Figure 9. Test and Application Circuit, we are able to built it? What does 1/2*Rs means? ?Rs = Supply Resistance" Correct if I am wrong. Thanks |
#9 | |
Anyways, yes you are correct! It does mean half supply resistance. Remember that the chip will work even better on a balanced input which it is also designed for. In that case both the IN+ and the IN- should have a resistor equal to the supply resistance. The advantage of the balanced signal in cars is evident because of the many radio signals that those long cables from the headunit to the amplifier is exposed to.
| Only N-Channel MOSFETs (NMOS); better Audio from non complements by Audio Power? | tiefbassuebertr | Solid State | 43 | 22nd January 2012 12:50 PM |
| For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp | tmort | Swap Meet | 5 | 27th June 2009 12:29 AM |
| Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D | jaimegmr | Car Audio | 0 | 5th May 2009 06:39 PM |
| Looking for analog audio circuit designers and audio researchers | cnotley | Everything Else | 1 | 29th September 2008 09:04 PM |
| 2.4GHz wireless audio - true lossless audio | Kay | Digital Source | 0 | 30th January 2008 10:22 AM |
| Page generated in 0.08983 seconds (79.86% PHP - 20.14% MySQL) with 10 queries |
