Old 18th August 2004, 08:47 AM   #1
Zemo is offline Zemo  United States
Default gainclone as a car amp?
Hey all. I want to build a gainclone as a simple car stereo amplifier, and mount it in the dash. It will have auxilliary inputs and the like, but I just need to know how to wire it up... I get +14.5V and 0V rails to work with. To put enough power to the chip what do I need? Would just getting a DC-DC converter work? (I recently discovered DC-DC converters). I'm using BrianGT's boards.
My guess is that I'd take a 15V input +/- 12V output DC-DC converter and wire up the +12V to V+, -12V to V-, and wire the com pin to PG+, PG-, OG, and CHG....or actually any one of those, since the board ties all of those together...
Then just wire the in's and out's as normal?
Any help is much appruciated!
Old 18th August 2004, 09:28 AM   #2
li_gangyi's Avatar
hmmm...+ / - 12V would get really iffy...not sure it'll even work at this voltage though...try something higher...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 18th August 2004, 10:54 AM   #3
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
or try a opa541 / opa549. from the datasheet:
WIDE POWER-SUPPLY RANGE:
Single Supply: +8V to +60V
Dual Supply: ±4V to ±30V
Old 18th August 2004, 11:38 PM   #4
rwaudio is offline rwaudio  Canada
Send a message via MSN to rwaudio
or you could steal the power supply section out of another amp... like this:
Old 20th August 2004, 01:49 AM   #5
Cool, thanks.
Just so I know... a DC-DC converter won't work? They are small IC's that convert one DC voltage input into another DC voltage output.
Here's the datasheet for one that I thought might work:
http://www.cdpowerelectronics.com/pr...c_hpr4xx_g.pdf
Is there some reason this won't work? To be honest, I don't really know very much about them....
-Z
Old 20th August 2004, 02:55 AM   #6
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
tda1521 is a good choice.
Supply with +/-12V,in bridge mode can get 2x30W power.
Old 20th August 2004, 03:02 AM   #7
Brian Donaldson's Avatar
You'll need a little more than 30 ma to run an amp
Old 21st August 2004, 05:11 AM   #8
I'd rather not run bridged...how much voltage should I try to get to get a reasonable amount of watts without going bridged?
...and how many mA would be a good amount?
-Z
Old 21st August 2004, 05:51 AM   #9
Send a message via Yahoo to mikelm
-Z
I did get a very nice sounding result from just 12.7 volts using 2 x tda2050 per channel with a phase splitter at the i/p to give balance working. with efficient speakers this might be a good bet.
but when experimenting later wth lm 3875 also in balanced mode the best rail voltges came out at about + / - 24V
as I increased the voltage the sound became bigger and more dynamic.
I would think you will need a power supply that can give a minimum of 3amps continuous and perhaps 5A peak.
if you use DC to DC converters I would imagine that you will need at least one C L C filter to remove HF noise.
good luck
mike
Old 21st August 2004, 06:05 PM   #10
jackinnj's Avatar
don't forget that you can use the LM3875 or LM3886 in single-supply mode -- but you will need 2X the voltage, so you will wind up using a "boost" converter anyway.
i have (not in use now) an LM3875 with a switching power supply mounted in a PC-type power supply enclosure. i retained the fan and this adds greatly to the heat-sink's ability to wick away energy. the device was in the trunk of one of my MB's so there was no fan noise. (the rear sway-bar of the MB is shot, so it only goes short distances now!)
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 03:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 12:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 07:58 PM
Page generated in 0.11748 seconds (78.40% PHP - 21.60% MySQL) with 11 queries
