Old 17th August 2004, 08:51 PM   #1
percy is offline percy  United States
Default Need suggestions for basic chip amp kit
Hi, glad to find a forum for "Chip Amps"!
I want to quickly build a small amp for use with "Speaker Workshop". Its a software that uses your sound card to measure impedance and acoustic response of a speaker.
Power is not critical - I believe 5-10W should be MORE than enough - but the amp should have pretty good noise/distortion figures and frequency response. (Noise better than -80-85db , THD/IMD better than 0.1%, ideally 20hz-20Khz response). I looked around for some kits and this by far is the best I could find for the price - Its a Vellemann kit (K4001) based on the TDA2003.
http://www.audioxpress.com/bksprods/kits/kv-k4001.htm
http://www.partsexpress.com/pe/showd...number=320-214
Budget is a constraint and I dont want to go much higher than what these kits are going for.
Any other suggestions or better alternatives ?
Thanks!
Old 17th August 2004, 09:24 PM   #2
Run for your life before the addiction is too strong to fight...
Otherwise, see
BrianGT's NI GainClone
I just ordered parts for my third one. Haven't fired up the Adcoms in months!
Simple, inexpensive, top quality sound.
Old 18th August 2004, 02:23 PM   #3
I am sure it must be a very nice amp. However, one thing I have noticed - you have to be careful with these little chip amps is that even though the 'core' schematic looks so simple and innocent, the power supply is usually a monster and eats up all your budget. No doubt its a very important part of the completed amp, but defeats the purpose for me.
I want something more simple that can run off my single 12VDC 2A wall transformer or a battery put together.
Secondly, it doesnt matter how it sounds or what type of tonal characteristics it has as long as it has decent noise, distortion and frequency response figures. I will almost never use it for music, only measurements.
Old 18th August 2004, 03:03 PM   #4
The restraints you are putting for your project seem a little hard.
To start with there's not much you can get from a 12V/2A supply, particularly if they are wall transformers. Most quality chips work with a split supply, so you will have to get a doubler circuit on line or use a DC-DC supply to get more power. That will also cut your amps.
There are some old chips, like the TDA2003, that did work on a car's voltage only, and you could get about 6W on 4 ohms. But distortion figures and noise were not that good. That power is also for a 14.4v supply, which is what you have on a running car.
http://www.ben.cz/download/121098/tda2003.pdf
You can bridge two of them, to get more power and eliminate the obligatory output series capacitor, but you won't get too much. Perhaps 10W into 8 ohms. Worst distortion figures too.
In the end you might be better served by a more modern chip, like an LM1876.
But you should think different and discard the wall supply.
Just my opinion.
Carlos
Old 18th August 2004, 03:35 PM   #5
Mr Evil is offline Mr Evil  United Kingdom
If you're worried about the cost of the PSU, pick up an old stereo from a car boot sale or wherever. You should be able to pull out enough for a complete PSU from one: transformer, rectifiers, reservoir capacitors, even connectors, switches fuses etc.
https://mrevil.asvachin.eu/
Old 18th August 2004, 04:08 PM   #6
Here's something you might want to try- www.si-5.com Look under " all products", then Class T amp. Good sounding amp,15w/ch,will run off 8 AA batteries or 12V wall wart. They list it as retailing for $39,but if you do a search on Google,you will find them for around the $20 mark.Might be just what you are looking for.
First chip amp - Looking for suggestions peter_m Chip Amps 4 9th January 2008 10:13 PM
a basic diy question for my chip amp then_dude Chip Amps 12 13th October 2007 11:05 AM
Suggestions for DAC Chip dsavitsk Digital Source 8 21st August 2007 04:49 PM
Very basic chip amp question leadbelly Chip Amps 3 13th August 2003 04:25 PM
Page generated in 0.08963 seconds (82.04% PHP - 17.96% MySQL) with 10 queries
