| Chip Amps Amplifiers based on integrated circuits |
diyAudio Moderator Emeritus
Should the pot shaft be insulated from the chasis? i.e. do you use some plastic isolating washers to mount it to the chasis? Is the shaft extender used in Peter Daniel's group chasis for isolatation purposes as well?
I am going to use the Vishay Sfernice P11 dual 10k linear pot with a 1.5k ohm law faking resistor with my GC (brian's kit). What wattage is required for the resistor? Is 0.25W enough?
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#2 |
I use plastic tube out of convenience only, and never though about isolating the shaft (although it seems to be isolated that way). The pot's housing is connected to the chassis anyway, and it's better when it is, as it's provide extra shielding. As to the shaft, I don't think it matters.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 | |
If the knob is plastic you don't need to worry about it. The faking resistor can be .25W. Carlos E. Martinez |
#4 |
I think I'll go with a 6mm OD plastic tube from B&Q if I can find one and use the shaft extenders from an old dismantled amp, and attach the pot housing without washers. Thanks for the replies.
How important is the quality of the resistors for law faking?
| Some Quad els57 questions! - Novice Questions! | Fanuc | Planars & Exotics | 13 | 5th December 2007 09:26 AM |
| PSU for QSC amp questions | rkc7 | Parts | 5 | 10th November 2005 05:18 PM |
| Last questions about this | Madmike2 | Multi-Way | 9 | 13th June 2005 11:12 PM |
| Questions, questions, from newb DIYer | Phatman91624 | Multi-Way | 41 | 3rd August 2002 02:52 AM |
| Page generated in 0.07733 seconds (70.79% PHP - 29.21% MySQL) with 10 queries |
