| Chip Amps Amplifiers based on integrated circuits |
#21 |
Ok, now i've got some idea of whats up
Kinda dissappointing actually. Basically I need a bigger PS. But first the real story. Ok, so we hooked it up, the only clip leads still attached were input gnd and from the output of the input buffer to the chip inputs. We hooked the whole thing up to the scope, and noise/occillations like crazy. Yikes. So we tested the output of the input buffer, and that looked pretty. Then we tested each parallel side of the amp individually. The - side, then the + side. Both of those looked good. When we hooked them together (bridged), oscillations like crazy. So, what I need to do now, is rip out the clip leads, and solder in real wires, and see if that helps. Ok, now as for the power. Looks like i'm getting (before bridging) about 30 watts out of each parallel side RMS into 8 ohms and close to 50 watts into 4ohms (dang it...could have done this w/ one chip!). Maybe a touch less. The ps voltage just isn't high enough, and it sags 3-4v per rail when the amp is just beginning to clip. So, first I'll solder the input wires, if the oscillations are really robbing of lots of power, then maybe i'll keep the current PS and use it and deal w/it. If I can get rid of the oscillations and the power output is still not adequate, time to get a big toroidal and slap it into my tiny chassis and see what happens -Matthew K. Olson |
#22 |
Ok, soldering in real wires instead of clip leads. There used to be a buzz coming from the tweeters, no more buzz. There is still a hum, but it is minimal
I may just build up the other monoblock amp as is, because i really don't want to throw any more money at this project...and because there is no room for a nice toroidal in this chassis. Oh well. I already have the other monoblock chassis drilled, so I guess I might as well just use it. Now I know the design works, and if I want to do it right, i'll get pcb's made and make things eaiser on myself. ptp for a gainclone is easy, for 3 parallel chips...what a pain. Its sure is cool looking though ...i'll post listening impressions when i get the 2nd amp done. Later-Mathtew K. Olson |
#23 |
Banned
You need one trafo per channel at around 400VA (National says 380VA), or, better, 500VA.
I would use 2x22 or 2x24V trafos. And... those MUR860 diodes are good for two chips, you have 8.Please, use those 35A metal-case bridges there. If you want to fiddle with serious power, don't think it's cheap. You need a decent PSU, heatsinks, etc. The amp will not be small. Otherwise, use just one chip per channel. Your trafos and rectification are just perfect for that. |
#24 |
Oh yeah, i know
Next amps will be more powerful. This PS just happened to fit in this case, and so did 6 chips. Way more complicated than it had to be. Oh well. Btw, those diodes don't get as hot as you might think. They were tested. Anyway, thanks for the advice though, although i'm well aware of the need for almost obscene ps's i'm usually a fan of excess ![]() -Matthew K. Olson |
#25 |
it didn't get hot because the trafo couldn't put out the required current I guess...
Kids in the back seat cause accidents...Accidents in the back seat cause kids... |
#26 |
That sounds valid. Trafo's are probably not uh, sufficient. Oh well. I'll get em next time
#27 |
why not just put 3 lm3886 in paralel insted of 2x3bridge/paralel
I personaly tested both and canot say that I prefer one of them. My experiece with the mur860`s are not that good(one 3875 pc) they sounded a little harch and not as open as two MB252 bridges. Does anyone have simular experience on that? This is the way the bridges are connected...... http://www.geocities.com/rjm003.geo/...s/diy_gc2a.gif |
#28 |
Well, the 3 in parallel work just fine, you are right about that. The only thing is, the configuration i have my chassis in, it wouldn't be ... convenient. So, i'm finishing the 2nd chassis bpa-200 as we speak.
#29 |
Ok, both bpa-200's w/ 6 chips are working... monoblock style
I know that the ps's are a little small, but the amps are dang small as well. 2 rack spaces each They sound quite nice. Pics to come soon. -Matthew K. Olson |
#30 |
Hey Matt, lets see those pics
It's better to have loved & lost than to never have had a good pair of speakers at all....... |
| Working with Current O/P DAC Chips | Eli Duttman | Tubes / Valves | 30 | 17th May 2011 06:26 PM |
| Blown MOSFET Chips -Pics- | nfueston | Chip Amps | 7 | 20th June 2009 06:31 PM |
| Page generated in 0.11516 seconds (74.08% PHP - 25.92% MySQL) with 11 queries |
