| Chip Amps Amplifiers based on integrated circuits |
Hi all
I've got a LM4780 amp running pretty nice, thanks to some helpful hints from you guys. Now I want to switch the mute on and off from a microcontroller, and this is causing me great confusion. I thought I had it sorted with a npn and pnp transistor tied together, it worked in my head but not in the real world apparently. Anyone done anything like this before? The output is 0/3.3v, 3.3v can be on or off doesnt matter, but I need to switch the mute resistor on and off, ie connect it and disconnect it from vee (about -30V) Just need to know how to connect it all together, I'm sure I'm close, I don't want to have to use a relay or something silly like that for this! Cheers guys! Ed |
#2 |
You didn't tell us which MC are you using, but you can use something like this, using the 16f86 microchip.
Sibstitute the led with a transistor and you're done. bye!
Fabrizio |
#3 |
just a pic, can do about 20mA I think
Now which LED?! Or am I being thick? |
#4 |
What about using an opto - coupler?
The input or driving side is driven like a led, the output side could be a transistor or fet or thyristor,,,,, there are many types. With the isolation this method gives you, there will be no problem with the -30v rail. It will interface easily with a microcontroller. |
#5 |
Interseting idea, really looking for a solution just using parts I've already got. THis really shouldnt be difficult, perhaps I should sleep on it!
#6 |
Banned
10k resistor from the Mute pins to V- : sound.
Direct connection from the Mute pins to ground: no sound. I would do it with a simple switch. Why a microcontroller?
#7 |
with a microcontroller, you could make an IR sensor turn on, or signal sense turn on, or ect. possibly so you can control the amp from a computer?
if only it could be used for good, not evil... |
#8 | |
Oooops, wrong image. anyway, you just need 1 mA for both channels, it's quite simple to achieve with the image I've attached. The MC have to drive a transistor, the trans opens up and the current flows as in the picture I've attached. The intended picture of my previous post is the following. Bye!!
Fabrizio |
#9 |
Fabrizio |
#10 |
but that won't work, the emitter will be at -30v, and the switching voltage is 0 / +3.3 result is that the transisotr is always fully suturated, whether its at 0 or 3.3, since they are both much higher voltage than the -30v of vee attached to the transistor.
Thanks Ed |
| Having fun with a PIC16F84A microcontroller | ikoflexer | Solid State | 8 | 20th August 2009 10:15 AM |
| Microcontroller Help | imix500 | Parts | 8 | 3rd September 2008 02:49 AM |
| help with microcontroller | sss | Everything Else | 2 | 31st July 2008 04:30 PM |
| Mute on BrianGT LM4780 PCB ? | AmA | Chip Amps | 15 | 22nd May 2005 10:25 PM |
| please help - no mute but did mute mod - tda1541 | loomis | Digital Source | 1 | 14th November 2002 10:54 AM |
| Page generated in 0.10135 seconds (74.33% PHP - 25.67% MySQL) with 11 queries |
