Old 16th August 2004, 01:54 PM   #1
w00t is offline w00t  Singapore
Default Is the 1.1A diode sufficient?
Hi all,
Is the 1.1A Schottkey diode sufficient for my gainclone project? The diode is going to be used in the rectifier bridge.
Transformer rating is 200VA, 18-0-18. I could use 2 bridges, 1 for each channel if it can't handle the current in 1. I'm also thinking of running the diodes in parallel in each bridge. Is it possible?
Opamp used is the LM3875.
Thanks, and cheers!
Old 16th August 2004, 02:28 PM   #2
jsd is offline jsd  United States
I'd say 3 amp is the absolute minimum you could use for the bridge, and even that would probably not be nearly enough. I'd shoot for at least a 5 amp rating with more being preferable..
Old 16th August 2004, 05:52 PM   #3
It is the surge current rating that should be of concern. Depending on the smoothing capacitance you are using i.e more capacitance needs more surge current rating. Schottky's generally do not have as good a surge current rating. A 5A ordinary diode might have a 300A surge but the 5A schottky might only have 50A surge. The fashion for schottky's is not one I would follow.
+/-15V power to a TI PGA2310. 15V regulators sufficient or do I need adjustable?? nick_g_evans Parts 2 16th July 2008 11:50 AM
hybrid power supply: diode bridge into diode tube engels Tubes / Valves 8 24th September 2007 09:18 AM
Sufficient power for the Fountek JP-2.0? mazeroth Multi-Way 3 20th April 2005 03:37 AM
Is 12dB/octave sufficient for subwoofer? skyraider Subwoofers 13 27th February 2005 03:21 PM
2 x 750va toroids sufficient for leach? Wagener Solid State 1 2nd May 2004 02:14 PM
Page generated in 0.07510 seconds (71.21% PHP - 28.79% MySQL) with 10 queries
